Old 04-10-2004, 04:10 AM   #1
PizzaDude's Avatar
Default countersinking: what Dremel tools to use?
Which Dremel tools have the right angle when I want to countersink screwholes?
For instance like at the bottow of a chassis????
Thanks.
Regards,
Pizza (with holes)
PizzaDude is offline   Reply With Quote
Old 04-10-2004, 01:21 PM   #2
SlobbaTech's Avatar
Dremel sells a bit, think it's meant to be used as router bit, but the angle on it is super close for flat head 4-40 screws. It's 2 flute, think on packaging it says 1/4" for diameter.
SlobbaTech is offline   Reply With Quote
Old 04-10-2004, 01:52 PM   #3
pro3racer's Avatar
does anyone know what threads and size is it for a set screw, a pinion screw, that one, i'm making a custom allen wrench driver, and i need to know what screw to use. Look at a dynamite wrench if you have questions.
pro3racer is offline   Reply With Quote
Old 04-10-2004, 02:03 PM   #4
Usually it is a 4-40 which uses a .050 wrench.
Ted Flack is offline   Reply With Quote
Old 04-10-2004, 06:32 PM   #5
Tek Nickal's Avatar
Regular pinions use .050, Robinson Racing Pinions use 1/16.
Tek Nickal is offline   Reply With Quote
Old 04-10-2004, 09:31 PM   #6
SlobbaTech's Avatar
4-40 is the .050" wrench, 5-40 is for 1/16" wrench
Old 04-10-2004, 09:33 PM   #7
pro3racer's Avatar
Thanks guys, that helped, i'll have pics of when it's done. It sucks, i don't know how to use a cnc lathe/mill yet(taking a class next year), so i have to make the whole thing by hand with a lathe and a drill press.
Old 04-10-2004, 10:10 PM   #8
Smoke21's Avatar
Location: Pacifica, California OR Clearlake Oaks, California
Send a message via AIM to Smoke21
buy one for your cordless drill if you have one it works better since you have more control of the drill then a dremel
Smoke21 is offline   Reply With Quote
Old 04-11-2004, 12:11 AM   #9
PizzaDude's Avatar
Slobba or anyone,
Do you have a partnumber for me?
Old 04-11-2004, 12:07 PM   #10
SlobbaTech's Avatar
http://www.dremel.com/html/home_fr.html
Better to use drill press over dremel for better control (mainly speed and with dremel sometimes the material takes heat from going too fast rpm then bits want to pull themselves into it drilling/sanding further than you wanted and that's not a good feeling) or drill unless you need to use hand tool to be able to do whatever comfortably.
Old 04-12-2004, 02:25 AM   #11
Send a message via ICQ to Cobra81li200
If it's for a chassis, I assume it's a carbon chassis, right ? In this case, I wouldn't use this dremel tool, it's not hard enough and will just wear very fast.
I recommend using a drill with a 90 end, better if it's a tungsten carbide or anything similar. For M3 holes, a 10mm drill works just fine.
Cobra81li200 is offline   Reply With Quote
Old 04-12-2004, 02:29 AM   #12
Default hand tool
you can buy a hand counter sinking tool that will work heaps better then a high spining version cheap as too.
KIMCOM RACING Driver #1
RC8B : REEDY 121 : Nitro-X fuel : Spektrum Radios
gkp5569 is offline   Reply With Quote
Old 04-12-2004, 03:21 AM   #13
rough512's Avatar
A conical grinding stone with a rounded tip works for me. I was able to create countersunk screw holes on CF chassis with plenty of control. Trial and error until a sample screw is just about flush with the chassis.
This was for about 8 holes only, the stone showed no sign of wear. You might need more than one stone.
rough512 is offline   Reply With Quote
7.2 Dremel II Fast R/C Items: For Sale/Trade 8 05-24-2008 09:28 AM
RC TOOLS PMB OFFROAD SETUP STATION**CORDLESS DREMEL**LITHIUM DRILL arm2storm R/C Items: For Sale/Trade 10 03-04-2008 10:43 PM
M18Pro - Wrong Size Countersinking = Broken Chassis Bobby Z Micro and Mini Scales 3 01-31-2007 11:25 PM
Countersinking parts: pros and cons bateman Electric On-Road 7 03-14-2005 05:24 AM
Dremel countersinking tool PizzaDude Electric On-Road 1 12-04-2004 04:11 PM
