Old 04-09-2004, 07:09 PM   #1
Default 414 MII/415 question
Since most of Tamiya's current TRF cars share the TA04 suspension is it possible to convert a 414 MII to a 415 by purchasing new bulkheads, the X-shaped fibre stiffner piece, belts and a bottom plate? The thing is I want a new car & theres a 414MII in the house (not mine, but I might be able to get it) and the 415 seems like the next big thing (and it'll take my flat packs) I don't mind if its a lil off 415 spec but I want somewhat of a basic version
The Black Kat is offline   Reply With Quote
Old 04-09-2004, 07:45 PM   #2
Not even close way too many parts you would need. You really need to buy the kit. The good news is you have spare arms and a few small parts
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 04-10-2004, 02:57 AM   #3
rccarracer's Avatar
It would end up costing more then the TRF415 kit, as you change everything but the suspension arms and hubs......
rccarracer is offline   Reply With Quote
Old 04-10-2004, 02:07 PM   #4
WC
WC's Avatar
Trader Rating: 28 (100%+)
Default Re: 414 MII/415 question
Originally posted by The Black Kat
...is it possible to convert a 414 MII to a 415 by purchasing new bulkheads, the X-shaped fibre stiffner piece, belts and a bottom plate?
also need 415's
diff (not same as TA04)
oneway (again its unique)
layshaft
pulleys
motor mount
the little CF plates on top of the bulkheads
shocktowers
swaybars
hingepin mounts
Or in short... the only things transferring from a 414 to 415 is the TRF shocks (are yours fluorine??), suspension arms/hubs/axles and the front bumper.
Most of which are 'consumable' and probably not in top condition on a well-used car.
Same logic could build you a EvoIII too, I guess. Won't be cheap.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 04-10-2004, 04:00 PM   #5
Default Forget that, I got a tub chassis 415! Too bad its not TCS legal :(
Nevermind....I ended up with a MR-4TC Worlds kit today.....Yay!
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 09:21 AM
Bolink TF drag car question and BL question parnelli97 Electric On-Road 2 08-20-2007 06:32 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 09:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 10:33 AM
