Weight Distribution - How to do perfectly? >
Old 04-10-2004, 01:18 AM
  #46
Tek Nickal's Avatar
I see people use 4 scales, one on each wheel . . .
Tek Nickal is offline
Old 04-10-2004, 01:22 AM
  #47
Speedie's Avatar
I would rather do it with 4. But the budget hasnt had room for that yet. I wish they made scale pads I could attach to my longacre scales for scaling full sized stuff then I wouldnt have to do any math when I scale.
Speedie is offline
Old 04-10-2004, 01:49 AM
  #48
Registered User
I heard 4 scale have calibration issue.
Aku-Man is offline
Old 04-10-2004, 01:54 AM
  #49
Speedie's Avatar
You would just have to level them with a small level.
Speedie is offline
Old 04-10-2004, 03:33 AM
  #50
Trader Rating: 22 (100%+)
The bigger the spur gear you get, the more the motor is moved to one side shifting the weight.
Kinda like a teeter toter, further out you go from center line more effect the wieght has Correct?
fastasu2 is offline
Old 04-10-2004, 09:48 AM
  #51
Speedie's Avatar
Exactly. The chassis centerline in the fulcrum.
Speedie is offline
Old 04-10-2004, 06:09 PM
  #52
Default 4 Scale System
I purchased a 4 scale system on Ebay. It comes with 4 postal scales and a flat board with 4 adjustable feet and a bullseye bubble in the middle to balance the board.
I setup my car yesterday afternoon and raced last night. The car was unbeleivable. I won every qualifier and the main for the first time in many tries.
I also found a good site to describe the balance process http://www.ground-control.com/?D=e04...ffa901ba6b5aaa
As Speedie has pointed out balancing the car is very difficult. I have not tried the lead weights yet. I just adjust the spring collars.
My car came out LF= 23.7%; RF=25%; LR=24.9%; RR=26.3%. This comes out to Lft/Rt=48.6%; Rear/Front=51.3%; and cross balance of 49.9% The total weight was 1430 grams. I was not able to get the weights exact, but it was close.
I also own the Integy System, which works very well. 4 scales are just a little faster, and possibly more accurate. Both systems worked much better than my previous tweak board.
Losi Lunatic is offline
Old 04-10-2004, 06:27 PM
  #53
Tek Nickal's Avatar
Man, your car sounds so good to being perfect, 49.9% on one side . . . .
Old 04-10-2004, 08:35 PM
  #54
It is actually not 49.9% on one side. This is the cross weight measurement where LF+RR = LR+RF. This is not that hard to do. The hard part is getting each side to weigh the same. My left side has only 48.6% of the weight compared to my right side
Old 04-10-2004, 08:42 PM
  #55
Tek Nickal's Avatar
Still, thats pritty close. . . You can adjust cross weight by adjusting shock preload right?
Old 04-10-2004, 08:47 PM
  #56
Here is a picture of my 4 scale system. Fiarly simple. I purchased it on ebay but it looks pretty easy to make
Old 04-10-2004, 08:49 PM
  #57
Yes, but you need to do what Speedie mentioned earlier, and adjust all four collars at once one turn at a time, to maintain ride height.
Old 04-10-2004, 08:50 PM
  #58
Tek Nickal's Avatar
Yeah. May try that, does it help handling or transitoning through corners better?
Old 04-10-2004, 09:02 PM
  #59
I put the car on the track for practice last night and it handled better than ever. The only major change for the week was the scale system. I race at Hobby World in Gilroy, on carpet, and the inside of the track is pretty tight. I was able to get around the corners with more confidence and speed.
Old 04-10-2004, 09:42 PM
  #60
Registered User
That four scale system look really nice. Is that custom made?
Aku-Man is offline
