Old 04-09-2004, 11:46 PM   #31
Registered User
I can't move anything else. I'm thinking put 20g at RF and 28g at RR. But if I put weight, that is going to change the ride heights right?
Aku-Man is offline   Reply With Quote
Old 04-09-2004, 11:46 PM   #32
Speedie's Avatar
I use 56 g to balance out my BMI next to the servo.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 04-09-2004, 11:52 PM   #33
Registered User
SpeediePHATT, can you post pic of your car? Just want to see how you put 56g weight. That is like eight of 7g lead.
Old 04-09-2004, 11:53 PM   #34
TC3Racer67's Avatar
Send a message via AIM to TC3Racer67
that's a sweet car Aku man! What are you planning to race on? I like the rayspeed chassis, but isn't it one of the flexiest chassis they make?
TC3Racer67 is offline   Reply With Quote
Old 04-10-2004, 12:01 AM   #35
Registered User
Yeah, This chassis is pretty flexable like xray m18 , but I think original SD has more flex than Rayspeed. I never try the original chassis, so I'm not sure. I don't care the car flex. As long as the chassis flex back and not stay tweak. Haven't try my CGM yet. I race outdoor at parking lot. Still waiting owner to find place for indoor.
Old 04-10-2004, 12:37 AM   #36
Speedie's Avatar
What I did was glue the weights together with super glue and servo tape them in place up front to the chassis and against the servo/reciever. When I want more rear weight I have one that I switch to that bolts on the chassis next to the motor where the nerf bars mount on the BMI chassis.
Old 04-10-2004, 12:41 AM   #37
Registered User
Default Big Q's
SpeediePHATT, I see many car pics of Factory Team Drivers. I don't see them use put weights as many as we needs. Some of them not even have weights. How did they manage to do that?
Old 04-10-2004, 12:43 AM   #38
Registered User
That's a lot.
SpeediePHATT, where did you get that scale?
Old 04-10-2004, 12:48 AM   #39
Speedie's Avatar
I have some pros setups that use alot of weight. But I see alot of pictures also and dont see alot of weight either. To balance out my TC3 with the stock tub tho. It only took 14 grams, but the BMI is more balanced design wise. Wheras the tub is heavier on the right side so you dont need as much weight to balance out the batteries. I can change how much I need also by runnig a bigger spur. Just going from a 100 to a 108 spur moves the motor enough to take 21 grams off.
Old 04-10-2004, 12:51 AM   #40
Registered User
Spur? I don't understand that theory. I still have lots to learn. How did you calculate that?
Old 04-10-2004, 01:00 AM   #41
Speedie's Avatar
I know it sounds like alot but how can you argue when the numbers are right there. I got that scale off ebay for 10 bucks. Someone on another forum mentioned moving the motor away from the centerling to increase right side weight so i figured out what the biggest spur I could fit in the car wich was 108 the biggest the LHS had. and weighed it like that. But I have a 100t spur in it now. Believe it or not the difference between a 100 and a 108 I could feel. It screwed up the throttle feel for me it felt flat off the corners and at the end of the straight.
Old 04-10-2004, 01:11 AM   #42
Tek Nickal's Avatar
The bigger the spur gear you get, the more the motor is moved to one side shifting the weight.
Tek Nickal is offline   Reply With Quote
Old 04-10-2004, 01:12 AM   #43
Registered User
I see.
Old 04-10-2004, 01:15 AM   #44
Speedie's Avatar
This is what I use to scale with. I only use one scale. It will only weigh right to left, and front to rear. Then I set tweak on a tweak board or on the track. the platform I built it the exact same height at the scale surface it sits on.
Old 04-10-2004, 01:16 AM   #45
Speedie's Avatar
another without car
Integy Weight Distribution System porschejim911 R/C Items: For Sale/Trade 0 04-12-2008 07:42 PM
Carpet Oval Set Up Weight Distribution? kang45 Oval, Larger Scales and More 1 01-16-2008 01:58 PM
Weight distribution on touring sedan OscarF1 Electric On-Road 11 05-01-2007 02:02 PM
Weight Distribution system speed6 Electric On-Road 10 09-22-2005 09:20 AM
Integy weight distribution system fire929 R/C Items: For Sale/Trade 9 03-26-2005 02:50 PM
