Weight Distribution - How to do perfectly? >
Old 04-09-2004, 05:05 PM
  #16
Registered User
Here's the pic.
Attached Thumbnails Weight Distribution - How to do perfectly?-car-scale.jpg
Aku-Man is offline
Old 04-09-2004, 05:23 PM
  #17
Speedie's Avatar
Sweet looking car. Looks fast.
Speedie is offline
Old 04-09-2004, 05:26 PM
  #18
Registered User
I test drive the car last weekend. Have problem cornering. Hope this will solve the problem. Race tomorrow. Got to prepare. First time with this car.
Aku-Man is offline
Old 04-09-2004, 05:35 PM
  #19
Speedie's Avatar
good luck
Speedie is offline
Old 04-09-2004, 06:25 PM
  #20
Brandon R's Avatar
SPEEDY...you are sooo correct on people with...WAYYY more than 50 grand in a racecar...how they dont know how to set it up!!! As for yout tips i wrote alot down LOL...now for your stuff niceeee do one for the losi car please!!!
Brandon R is offline
Old 04-09-2004, 07:20 PM
  #21
PW
PW's Avatar
Everyone is on step 2 before they did step one. Weight balance should be done first before you put the car on any type of scale.
There are 2 quick methods: First way is to set droop and ride height with setup wheels installed. You then find the center point on your shock towers (f/r) and then you can suspend the car with string from those points (Schumacher towers already have it marked ). Next you lift the car until the setup wheels release or touch at the same time (must move components around until they do).
Another way is a similar method, but you rule out any suspension by placing a small balancing bubble onto the top-plate and suspend the car. Then move weight around until the bubble is centered.
Only then you can truly tweak a car on scales
PW is offline
Old 04-09-2004, 11:21 PM
  #22
Registered User
I found out the table that I work on is not perfectly flat. I relocate a flat spot to work on and reset the ride heights again from beginning. The measurment is very close. So, I don't think the scale is bad or my car tweak.
LF= 330g -------- RF= 310g
LR= 360g -------- RR= 332g
Aku-Man is offline
Old 04-09-2004, 11:30 PM
  #23
Speedie's Avatar
Originally posted by Aku-Man
I found out the table that I work on is not perfectly flat. I reset the ride heights again from beginning. The measurment is very close.
You still have 52% rear but now it shows 52% left weight percentage. Try adding 28 grams of weight on the right front side. That should put a little more up front and cut the rear percentage down and balance out the L/R percentages. Then when thats good reset the wedge.
Speedie is offline
Old 04-09-2004, 11:36 PM
  #24
Registered User
SpeediePHATT, How did you come out with 28g to add on FR? I'm trying to figure it out.
Aku-Man is offline
Old 04-09-2004, 11:40 PM
  #25
Speedie's Avatar
Your left side weight is 690g and your left side total is 662g the difference is 28g. Plus most people use tire stick-on weights for balast, and those are 7g each. And twards the front because you said you were having trouble cornering so you want less rear.
Speedie is offline
Old 04-09-2004, 11:41 PM
  #26
Speedie's Avatar
You cant move the batteries in your car can you?
Speedie is offline
  #27
Registered User
Isn't my right side weight 642g? 690 left - 642 right? = 48g?
Aku-Man is offline
Old 04-09-2004, 11:42 PM
  #28
Speedie wanna balance my car next?
R/C Anonymous is offline
  #29
Registered User
Can't move the battery.
Aku-Man is offline
Old 04-09-2004, 11:44 PM
  #30
Speedie's Avatar
oops bad math. then you need more about 40 or more see if you can move around something you already have.
Speedie is offline
