Good steering servo >
Good steering servo
Good steering servo
Old 04-08-2004, 05:03 PM
Neil's Avatar
Default Good steering servo
I am looking for a good steering servo. I tried to get the jr z8450 but its discontinued. What other servo has the same speed and torque. Or better.
Neil is offline
Old 04-08-2004, 05:14 PM
Futaba 9450/9451
True R/C Racing is offline
Old 04-08-2004, 08:21 PM
Super Steve's Avatar
KoPropo PDS2143FET is the BEST steering servo ever imo
Super Steve is offline
Old 04-08-2004, 11:47 PM
I actually stubled across using an Airtronics 94358.
If you take a look at the numbers they are pretty mind blowing on the torque end for a non-digital/non-Fet servo. On the track it has never let go in the corners. If you use a direct plastic horn you probably will shear it, instead I ended up using a HeavyDuty Kimbrough servo saver. Not a bad servo for around $100.
A-Ko is offline
Old 04-08-2004, 11:58 PM
rice's Avatar
Default Re: Good steering servo
bro get the s9451. depends also where will you use it in 1/10,1/8 on road or off-road.
enjoy racing
rice is offline
Old 04-09-2004, 04:39 PM
Neil's Avatar
Yea I got that 9451 in my sedan this servo is for a buggy tho.
Neil is offline
Old 04-09-2004, 10:40 PM
AdR|aN's Avatar
For 1/10 Ep - KO 2343
For 1/10GP,1/8Buggy - KO 2344
Just my 0.02
AdR|aN is offline
Old 04-09-2004, 10:46 PM
i personally use Airtronics 94257 old school servos...ive had the two i own for the past 5-6 years and they have never let me down yet and i race quite often...same gears and everything
R/C Anonymous is offline
Old 04-10-2004, 04:10 AM
Cole Trickle's Avatar
I'm very happy with my KO PDS 2123.
Personally, I find that a steering servo cant be too fast
So I'll recommend you get the best you can afford. If you go with good brands like KO, Fut, JR or Air, you'll probably have it for many years.
Analog servos can be as fast and strong as digital ones. If I had to choose between a slow digital and a fast analog, I would go analog. Ultimately, get a digital one, if budget allows it. Digital ones have better resolution and way more holding power. They are also stronger around the center, than analog ones are.
For EP cars, there's no need of programmable servos.
Cole Trickle is offline
Old 04-11-2004, 08:10 PM
wolfeman09's Avatar
So if the 8450 is discontined, does anyone know what JR is going to replace it with?
I am looking for another sterring servo for my 1/10 touring car a TC3.
I really like JR and would like to stick with them and digital.
thanks...
wolfeman09 is offline
Old 04-11-2004, 08:51 PM
DOMOisCOOL's Avatar
Ill second that! Super smooth servo.
DOMOisCOOL is offline
Old 04-11-2004, 09:32 PM
Neil Rabara's Avatar
I hadn't had any problems with my 357 Airtronics.
Neil Rabara is offline
Old 04-12-2004, 06:30 AM
mafiaracers's Avatar
Trader Rating: 22 (100%+)
HS-5925
mafiaracers is offline
Old 04-12-2004, 09:13 AM
TeamButter's Avatar
Airtronics-94758 Digital
.06 Transit Time and over 100 ounces/In of tourqe
my .02
TeamButter is offline
Old 04-12-2004, 11:32 AM
wolfeman09's Avatar
Thanks, but what about JR?
Do not want any other brands....
