Old 04-07-2004, 09:45 PM   #1
Fusedbrain's Avatar
Default Crystal question
Hi there,
This question must have been asked before but I can't find reference to it.
Can I use 75mgz crystals from one brand of radio in another brand. For example, futaba crystal in a hitech or Airtronics or vice versa? Please let me know.
Eric.
Fusedbrain is offline   Reply With Quote
Old 04-07-2004, 09:51 PM   #2
Fusedbrain's Avatar
Default Compatible crystals
Hey just to let you know it's 75 mgz FM.
Old 04-07-2004, 10:02 PM   #3
I was told that you cant.
stumper is offline   Reply With Quote
Old 04-07-2004, 10:07 PM   #4
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
From what I remember was that Hi Tech and Futaba do work together but none of the rest do. Now you can mix and match some with some receivers, thats more work then what its worth. So your better off sticking with stock crystals.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-07-2004, 10:19 PM   #5
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
in order to assure proper frequency modulation u will want to run whatever the manufacturer sells for there radio...
it may be posible for some to work with others but not for long.. crystals are a goofy thing.. and improper xstal can actually mess up a radio or reciever,, not to mention a car if it goes out of control...
there are some offbrand companies i have seen people buy xstals from.. they were suposed to work with any company. and all of them stopped working after a few times. and or glitched like crazy.... some of them actually messed up the radios to....
there isnt much price difference from company to company so u are better of just getting the proper set....
ive been racing 16+ years and i always buy from the man i have the radio for,, i have yet to have a bad crystal....
same goes with recievers,,, every novak or tekin reciever i ever used lasted maybe a month or so.. i have stuck with the stock recievrs since and have never had a problem... when the radio leaves the factory they are suposed to be factory tuned to there exact specs..
my cars are pretty expensive.. so the extra little i spend to assure a proper working system is way worth the price of r4placing parts after a radio huit into the wall...
just my 2 cents....
burbs is offline   Reply With Quote
Old 04-07-2004, 10:56 PM   #6
Andrew_XXXs's Avatar
I don't know about 75mhz but I bought quite cheap generic xtals for my 27mhz and they've worked great for quite a while now.
Andrew_XXXs is offline   Reply With Quote
Old 04-07-2004, 11:15 PM   #7
Fusedbrain's Avatar
Default Crystals
Well thanks to all for the input. I just bought a used M8 and have one crystal set for it and was wondering if I could put the crystals from my Futaba and Hitech. Looks like I should simply go out and buy a set from the manufacturer if I want another set. But it looks like some people have had good results with after market sets.
Eric.
KO crystal question wikedgmc Electric On-Road 0 09-24-2006 09:47 PM
crystal question? S14SR20det Rookie Zone 2 05-30-2006 10:32 AM
Radio Crystal Question PROVK Australian Racing 2 05-25-2005 04:33 AM
27MHz AM Crystal Question Sport Crystal Australian Racing 34 09-02-2003 07:49 PM
