Comparing Pistons >
Comparing Pistons
Comparing Pistons
Old 03-05-2010, 06:43 AM
Tech Legend
Cain's Avatar
Trader Rating: 274 (100%+)
Default Comparing Pistons
Was curious about this so I figure some of your gurus out there can answer.
Is there a formula you can use to compare pistons to each other?
Example:
- Piston 1 - 2 hole with 1mm holes, what would be an equivalent 3 hole piston and same question in reverse?
Cain is offline
Old 03-05-2010, 07:19 AM
seaball's Avatar
assuming the same thickness and overall diameter of the pistons, you can probably compare them using the formula for calculating the area of a circle (pi * r^2). sum the area that the oil will flow through and that should be ballpark.
if you're switching between piston mfrs, things like the edge radius and hole tapers can affect the dampening as well, and are much tougher to calculate/predict.
seaball is offline
Old 03-05-2010, 07:33 AM
PitNamedGordie's Avatar
So do you mean like this?
I am running Tamiya 4 hole pistons bored out to 1.4mm.
(3.1416*1.4^2)*4 = 24.63 square mm?
PitNamedGordie is offline
Old 03-05-2010, 07:42 AM
seaball's Avatar
close.
3.14 * (0.7^2) * 4 ~/= 6.15 sqmm
realistically, pi doesn't even need to be there for the relative comparisions, but let's not ahead of ourselves.
seaball is offline
Old 03-05-2010, 08:15 AM
close.
Gotcha
Oh and uh..I knew r was radius not diameter
