Battery Help
Battery Help
Not sure if this post is ok in this forum. Let me apologize in advance if it is not. I have a question concerning one of my lipos. I tried to charge it yesterday and my charger began to been and read wrong voltage. I thought my wall outlet was not strong enough because I used a different one than normal. I changed it to the outlet I always use and it still would not charge. I then swapped the lipo out and it charged the different lipo just fine. I assume my lipo is dead. I got it used so I don't know how many cycles it has on it. Is there something I can do to fix it? It does not look any different than the day I got it. Not swollen or smell burned or anything like that. Please let me know if you have any ideas.
More info. needed. Manufacture of lipo,2s or3s? MAH? Type of charger and balancer? Use a DVM tell us the voltage on lipo's
DVM reading on the Reedy 3200. should have 6v on it. If lower than 5.5v Charger should give you an error. Maybe say"cell too low". Lipo's are not suppose to be discharge to 0 volts like ninh's. Discharge lipo to 3v per cell Reedy 3200 to 6v. You may try to charge it to 1000mah see if it will take a charge. Rather you have a balancer and cycle the pack a few times. over dischaging can damage lipo's.
If the lipo's read at 8.4v the charger will shut off after a few seconds cuz cell is charged, and won't anymore.
Here I am trying to get my 7.2v 3800mah t-energy packs charged to full, but before this happens, my charger is getting pretty hot. Im charging at 4 amps. switch is on 6 cell. any ideas? im lowering the charge rate as we speak.
Charger is a DYNAMITE vision peak 2 charger.
Tenergy pack are so sensative when charging. 4 amps could overcharge the pack. That why I said to set the charger at 3.8 amps, and top off by trickle.
Telling you the truth, Tenergy pack are cheap. They don't last long, in my opinion. Stay with the better brand, like Orion,Reedy,Duratrak, Trinity.
its ok to let it out about the packs. but yeah i would never charge without watching or let my precious t-energy packs get hot. its the charger thats heating up first.
there are new BTW. could this be the reason.?
Normal for the charger to heat up, especially ones that dosn't use a biult-in fan.
should i get a 3300mah 2-cell 30c or a 3000mah 3-cell 20c?
same problem.
bump
