Old 03-04-2010, 07:13 AM   #31
R/C Tech Charter Subscriber
Send a message via AIM to acyrier
yeah, I just like to hear from tekin wheather they think it's a good idea or not..I can't see why not. I'm one of the few people that has been using a 2s lipo for a reciever pack for a while and not have any issues. I've been using this:
http://www.horizonhobby.com/Products...rodID=LOSB0862
I liked it becuase it's got it's own charger. when I get back from turn marshalling, I plug the car in. There is plenty of "slack" in the wall charger to make mods on the car, verify setup etc. Some people complain about charging a second battery, but doing it this way, sure does minimize the work.
The products and places I support.
www.michianarc.com www.facebook.com/michianarc - www.russellrc.com
www.teamtekin.com - www.teamcrc.com - www.teamassociated.com
www.fantomracing.com - www.discountrcstore.com
acyrier is offline   Reply With Quote
Old 03-04-2010, 02:34 PM   #32
Team Tekin
Tekin Prez's Avatar
Originally Posted by mecam View Post
No need to use an external booster nor external regulator. Use the ESC's built-in regulator. This setup is the same as using a single 7.4v battery race pack to power everything. Many 12th scale racers have done this mod and have worked flawlessly for many many months. I have been using this mod for over 2 months now and no issues. Modify at your own risk and may/will probably void your Tekin warranty.
That is slick! Have to love user ingenuity Somebody understood what was going there pretty well.
We need to look at it closer before we endorse it. You are actually giving the esc control circuits 3s voltage and letting our regulators provide the 6V to the receiver. The only downside is that our bec regulators cannot put out as much current due to the higher supply voltage which should not be problem in the 1S cars.
Should actually work the same with a 1S lipo added on the switch line. That really gives us the 2s lipo voltage we want.
Tekin Prez
[email protected]
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Old 03-04-2010, 02:41 PM   #33
I wish I can take credit. I just copied the configuration from the fast guys at Norcal. The least I could do is draw the diagram.
mecam is offline   Reply With Quote
Old 03-04-2010, 02:58 PM   #34
el salvador's Avatar
Thumbs up
Originally Posted by RacinJ View Post
The Losi Micro T battery pack works perfectly. And I can still use my old charger.
https://www.ssl-stormerhobbies.com/c...ns&pn=LOSB0848
+1 on this option, I have 3 of them, Charge before every run @.5 amps.
Only issue, If you want to plug directly into Rx, you have to change the connector, but these little guys are very effective, and dependable.
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 03-04-2010, 04:37 PM   #35
theisgroup's Avatar
Tekin Prez
so jim would 1s in this configuration be Tekin endorsed?
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-04-2010, 05:12 PM   #36
Actually, I ADD another reciever connector and some wire... I charge it while it's in the car. Since the switch is "off" it's not a problem.
Old 03-04-2010, 05:47 PM   #37
gonzo416's Avatar
Trader Rating: 39 (98%+)
Can you post pics of it in the car?
gonzo416 is offline   Reply With Quote
Old 03-04-2010, 05:48 PM   #38
skypilot's Avatar
Trader Rating: 14 (100%+)
Tekin Prez
semi retired..
skypilot is offline   Reply With Quote
Old 03-04-2010, 06:07 PM   #39
I use a 700mah lipo that will last me 12 full runs and only need the Tekin switch to power all the eletronics and both batts.
Old 03-04-2010, 07:14 PM   #40
pakk's Avatar
Trader Rating: 79 (100%+)
As soon as Tekin puts their blessing on this setup, both my cars will be setup this way.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 03-04-2010, 07:37 PM   #41
Lost Aggresiva's Avatar
Huh? Looks simple enough. Just may solve my steering issues.
Bill.
Lost Aggresiva is offline   Reply With Quote
Old 03-04-2010, 07:46 PM   #42
theisgroup's Avatar
Bill.
that is funny, i am worried that I will loose steering. since we were feeding the servo at 8.4 and now down to 5.7
yang lai
Old 03-04-2010, 07:54 PM   #43
Unless you have a high voltage servo designed for 2s, you may have jittery problems feeding it over 7v and maybe killing the servo slowly. I think 5.7v is just perfect for most servos.
Old 03-04-2010, 08:00 PM   #44
theisgroup's Avatar
robert a Ko said all my ko stuff is designed for 2s
yang lai
Old 03-04-2010, 08:03 PM   #45
Yeah, you're good to go with the KO stuff.
