Reallll Hot Batts >
Reallll Hot Batts
Reallll Hot Batts
Old 04-06-2004, 06:30 PM
Brandon R's Avatar
Default Reallll Hot Batts
OK my batts on my nitro truck got realllll hot.... I was driving and the wire that goes to the reciever somehow got in between the gears!! They were exposed and were touching. Heres the question...Is the battery pack ruined? They got very hot but worked right before I took it all out. Is it ok to try and recharge them or should I buy a new pack?
Brandon R is offline
Old 04-06-2004, 06:34 PM
Speedie's Avatar
It shouldnt hurt anything to try them. As long as they didnt vent when they were shorted they might be ok yet.
Speedie is offline
Old 04-06-2004, 07:21 PM
Brandon R's Avatar
how i know if the vented? they didnt smell but the shrink wrap around the assembely did melt and tear a little
Old 04-06-2004, 08:09 PM
fatdoggy's Avatar
It's tough to say. I know people who have shorted out packs and they still work fine. I accidentally shorted out a pack two weeks ago and when I tried to charge it last week it kept false peaking. If they vent you'll see stuff leaking out of them or hear a hissing/spitting sound.
fatdoggy is offline
Old 04-06-2004, 09:54 PM
Brandon R's Avatar
ohh...i sprayed electronic cleaner on em to cool em and it made a hissing sound but im not sure if it was batts alone or the cleaner evaporating for the heat LOL
Old 04-06-2004, 10:57 PM
JusBox's Avatar
wow, electronic cleaner to cool them?
JusBox is offline
Old 04-07-2004, 11:40 AM
Brandon R's Avatar
yep worked real good too!
Old 04-07-2004, 12:01 PM
John Fontaine's Avatar
If you melted the casing, chances are it's probably toast. Get another pack or you might chance of a run away nitro which is not cool and I don't want that to happen to you.
John Fontaine is offline
Old 04-07-2004, 12:22 PM
Brandon R's Avatar
thats what happen when the wires get in the gear...it was on idle though and i had no control of steering or anything... it just kept rolling when i let off of it and turned itself and went in a circle and the run into a little bush and stopped...when i pulled the wires out from between the gears i got control back but the wires and connector were very hot so i took the safe route and turned it all off. Then i sprayed the cleaner on the wires cause they were smoking like a freight train and the on batts so i could take em out of truck
Old 04-07-2004, 12:27 PM
Take the safe path and buy a new pack. That pack is not going to be reliable and will cause problems if you continue to use it. Also, try and keep wires away from spinning parts!! Make sure they're zip tied and secure.
Old 04-07-2004, 01:46 PM
Brandon R's Avatar
they were tied down!! thats how i dont see why they come loose...the zip ties where still there but broke so i dont know what happen
Old 04-07-2004, 03:12 PM
AdrianM's Avatar
Replace the battery. Runaway Nitro cars are not fun.
AdrianM is offline
