Old 05-15-2004, 04:11 AM   #76
Turn Marshal's Avatar
Uhhhhh....you need to have a cut off of .9v per cell. Bringing your cells down to zero can be very damaging to you nimh cells. Hence, to decrease in performance in you 3000's. You really need to read up on proper maintenance of nimh's!!! They are NOT conditioned the same as nicads!!!
Turn Marshal is offline   Reply With Quote
Old 05-15-2004, 04:39 AM   #77
fatdoggy's Avatar
R/C Tech Charter Subscriber
Turn Marshal - SMC says otherwise.
fatdoggy is offline   Reply With Quote
Old 05-15-2004, 05:02 AM   #78
Arthur's Avatar
I'm not recommending bringing 3000nimhs down to 0v I did say it can do more harm than good in my post. Although I did have some success with the 3000mAh Panasonic stock metal hydrides which are supposedly not that robust a cell.
If you are running recent 3300s however there may be some advantage to going down to 0v as long as you do it properly. You should read the Dead Short thread Turn Marshal.
Arthur is offline   Reply With Quote
Old 05-15-2004, 03:36 PM   #79
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
yeeaahh ROOK!
just kidd'n
JayBee is offline   Reply With Quote
Old 05-19-2004, 04:46 AM   #80
17driver's Avatar
Is every one happy with the tray?Would you recomend it?
Midwest malitia member
17driver is offline   Reply With Quote
Old 05-19-2004, 05:42 AM   #81
Its cool. The only thing is you still need to use a 30A discharger first then use the smart tray.
If the tray was really smart it would first discharge your cells at 30 amps then automatically go into like a "matching mode" and match the cells at 5 amp.
So after spending $85 on this, I still need to buy or build a bulb discharger.
"Would I recommend"? Well if you already have something to discharge your cells at 30amp, then yes (if you got extra $) get one. But If you don't have anything to dump the cells then maybe you can find an alternative and spend less money.
datruth99 is offline   Reply With Quote
Old 05-19-2004, 06:08 AM   #82
That's a great idea, one unit does it all, don't say it out loud! or soon someone will steal your idea and come up with the product, it would be beneficial to us though...
Quiet is offline   Reply With Quote
Old 05-19-2004, 06:28 AM   #83
Hi Turn Marshal;
you might be right about the 3000 nimh but go to www.smc-racing.com and check out the new charging updates for gp3300's I already have shorted a new sms 3300gp pack, haven't used it yet they are stored with a wire across positive to negative terminal I will let know the out come of this new method of treating nimh's... at least it is to me!
Old 05-19-2004, 08:05 AM   #84
jeepnyy's Avatar
Who's got them in stock now ?
jeepnyy is offline   Reply With Quote
Old 05-19-2004, 09:27 AM   #85
rc-zombies's Avatar
STormer had some last time I looked yesterday..
Old 05-19-2004, 09:55 AM   #86
Originally posted by Quiet
Hi Turn Marshal;
it works great for stock racing .. really helps the voltage out ... keeps it high longer ... you do lose runtime tho ... but with 3300's who cares ... I was making 7 minutes with the packs I dead shorted when I first got them assembled ( I wanted to see how much runtime I actually lost after dead shorting ) after the dead shorting I can barely make 6 mins 15 secs or there abouts ... but I dropped an average of .2 to .4 secs per lap depending on which motor and track I was at ... so it is worth it ...
have fun racing
E
roddude65 is offline   Reply With Quote
Old 06-13-2004, 05:08 PM   #87
JayBee's Avatar
Post
i just got my smart tray and i like it alot; now i can start discharging my packs the right way
but i do have a stupid question-- when i use the tray to take the cells down with a .9 cut-off voltage, and then go to charge them, aren't they supposed to read 5.4V (.9v x 6 cells) on the charger initially? the tray is designed to take EACH CELL to .9v correct?
i'm getting a reading of 7.45-7.78v for my cells initially when put on the charger.
Old 06-13-2004, 05:19 PM   #88
The Evicerator
Once you take a load off the battery the voltage will rise back up to what you are seeing.... The higher the load, the lower the voltage should read... so no load = higher voltage...
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 06-13-2004, 05:43 PM   #89
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Yeah, but have you ever opened up a CE Turbo 30/35 charger to see the size of the heatsinks in there? Thats the main reason they are so big..
So not only will we have T-35's, but have a discharge/equalization tray of the same size?
...now where did my pit table go?
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 06-13-2004, 05:46 PM   #90
JayBee's Avatar
Post
whew, thanks, i was a little concerned there for a moment.
what charger are you using?
FS: Novak smart tray , discharger 7HEAVN Australia For Sale/Trade 0 11-27-2007 01:22 PM
Novak Smart Tray Discharger xraycer007 Electric On-Road 1 03-07-2007 05:55 PM
WTB: Equalizing Discharger (IE: Novak Smart Tray,etc) XXWoodmanXX R/C Items: Wanted to Buy 8 10-06-2006 04:32 AM
Novak Smart Tray Discharger John Q R/C Items: For Sale/Trade 8 02-14-2006 08:28 PM
Novak smart tray digital discharger fs sharkman R/C Items: For Sale/Trade 9 03-02-2005 11:00 PM
