Old 01-31-2005, 05:17 PM   #256
Send a message via Yahoo to mark pesce
Talking Dead short mode!
I don't know if anyone knows aobout this mode. But if you
unplug the unit and hold down the set button when powering
up' you will get a DS display when you release the button.
Just found this myself.
mark pesce is offline   Reply With Quote
Old 01-31-2005, 11:21 PM   #257
JayBee's Avatar
Trader Rating: 31 (100%+)
Post Re: Dead short mode!
Isn't that on the back of the box?
- JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 02-01-2005, 12:08 AM   #258
I have a tray on order, any chance you can post/host a pic of a 4 cell saddle pack set in a tray?
SteveB is offline   Reply With Quote
Old 02-01-2005, 05:29 AM   #259
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Originally posted by Losiho
Yes, I have the International Version, and the included input wire and plug will not fit into the power jack on the right hand side. What can be done ? Has Novak supplied the wrong input plugs ?
Komkit - How can you say the unit works well if you also cannot get the input plug to fit ? The unit will not work without AC/DC power.
The DC jack/plug (pigtail) that came along with the unit doesn't fit. The AC/DC adepter jack/plug fit just fine. But I like to use the DC jack/plug - so I went to an Electronics supply shop near by and bought a jack/plug that would fit and made the DC jack/plug myself. So, I don't have to drag the AC/DC adepter around.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 02-02-2005, 08:39 PM   #260
Charlie O's Avatar
Default 7 cells!
Anyone try equalizing 7 cells! do you put the pack in like a normal 6 cell, then take the single extra cell & while still attached to the pack disharge the 7th cell with the other 6 hanging off the tray?
Charlie O is offline   Reply With Quote
Old 02-02-2005, 10:13 PM   #261
Scottrik's Avatar
Trader Rating: 245 (100%+)
Default 7-cell discharging
I certainly don't know for fact, but I'd guess you could move the pack over by one cell so the "missed" cell is engaged and do it that way. The other 5 pre-discharged cells still engaged wouldn't discharge any further so only the one would continue to discharge down to your cutoff.
Scottrik
Scottrik is offline   Reply With Quote
Old 02-03-2005, 01:29 PM   #262
Charlie O's Avatar
Default Thanks Scottrik!
Last night i got a few beer under my belt and tried it the way i described, dicharge the first 6, then just discharge the seperate cell, i also tried it the other way, single cell first then the other six, sure made a big difference in the E-Maxx, I just love mad scientist experiments, by the way i got a new fire extinguisher today, (just incase)
Old 02-03-2005, 02:36 PM   #263
Trader Rating: 32 (100%+)
You sure the beer didn't make the difference? haha what kind of difference?
gulio is offline   Reply With Quote
Old 07-29-2005, 01:51 PM   #264
ttso's Avatar
Default Mod?
I just check the whole thread and seems no one actually did the higher discharger rate mod. The back cement resistor is 5W, 0.47Ohm, with result of 2.55A under 1.2V.
I wanna mod it to 10A discharge rate under 1.2V, makes 0.12Ohm with 12W. Is that the correct cement resistor I should get?
Also, I check over the circuit and found there is an IC 4410 on the path of cement resistor, I believe it's "N-Channel Enhancement Mode Field Effect Transistor" (PDF: http://www.ortodoxism.ro/datasheets/cet/CEM4410.pdf). It seems it can take 30V 10A maximum but with my target 10A discharge rate, wouldn't it be a bit on edge if I don't replace the IC for bigger current pass? I search over and found CED61A3 (PDF: http://web2.cetsemi.com/PDF/TO-251-252-N/U61A3.PDF) seems fit the spec with maximum 30V 40A. Is this the correct IC I should replace original one?
Sorry I'm not major in electronic so some question might seems stupid...
Reason for such mod? I love the feature of setting cutoff voltage and I don't wanna use other 20A discharger due to many reason. Mod the Smart Tray seems the best fit way for me.
ttso is offline   Reply With Quote
Old 07-29-2005, 04:12 PM   #265
Charlie's Avatar
I can't really confirm or Deny your modification, but I have some tips maybe.
Instead of discharging the pack at 20 amps to 5.4 volts, discharge it to 6.0 volts or even a little higher, THEN use the Smart Tray on them. This method seems to prevent the weakest cells from being over discharged during the main discharge. Also, if you "up" the current, the voltage cuttoff will not be as accurate as the load is higher.
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 07-29-2005, 04:29 PM   #266
tc3blue's Avatar
Ttso doesn't want to use another discharger, that's why he's trying to mod his SmartTray, but I use charlie's method all the time.
Keep us posted on your mod, Ttso, it'd be great if you get it to work.
tc3blue is offline   Reply With Quote
Old 09-01-2005, 12:18 PM   #267
RandomFellow's Avatar
Hey everyone, just thought I'd share my recent problem and solution with the Smart Tray in case this happens to anyone else. The problem was that the set button on the Tray was no longer returning from a full depression. If you were to push down on it, such as when you change the cutoff or start the discharge, the button would barely move and there would be no "click". At times, the button would get stuck all the way down so the cutoff value would just keep cycling. So, here's the problem and what to do:
Apparently, the translucent green plastice cover on the tray has a little slop. If the tray cover shifts enough to the right, the button will get interference. Just take your thumbs and push the cover to the left and your button should go back to normal, "click" and all.
RandomFellow is offline   Reply With Quote
Old 09-13-2005, 11:26 AM   #268
toritor's Avatar
Send a message via MSN to toritor
hi
i was wondering if the included wall adaptor included on the USA version is ready for universal use like 220 volt that is used in some countries of europe.
thank you very much
toritor is offline   Reply With Quote
Old 09-13-2005, 11:30 AM   #269
Charlie's Avatar
No, the adapter is only for 110. The Tray can be used from any 12 volt source though, so you can run it from your Power Supply. It uses under .3 amps.
Old 09-13-2005, 12:49 PM   #270
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Originally Posted by toritor
hi
thank you very much
Ask someone from your nearest electronic store. Im from Australia, and i bought most of my gear direct from the US etc from 110v countries. If you check out the specs of the product and check out the back of the wallplug, you will notice it will state the output of the wallplug. This is what is needed to run the smart tray etc. Just ask for a similar output transformer from your local electronics store, and about 90% of the time, it has the correct plug! As long as the output is correct, you wont have a problem using your own 240v wallplug to power you equipment.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
FS: Novak smart tray , discharger 7HEAVN Australia For Sale/Trade 0 11-27-2007 01:22 PM
Novak Smart Tray Discharger xraycer007 Electric On-Road 1 03-07-2007 05:55 PM
WTB: Equalizing Discharger (IE: Novak Smart Tray,etc) XXWoodmanXX R/C Items: Wanted to Buy 8 10-06-2006 04:32 AM
Novak Smart Tray Discharger John Q R/C Items: For Sale/Trade 8 02-14-2006 08:28 PM
Novak smart tray digital discharger fs sharkman R/C Items: For Sale/Trade 9 03-02-2005 11:00 PM
