Old 09-23-2004, 12:52 PM   #211
basementLOSI's Avatar
Send a message via AIM to basementLOSI
Originally posted by Evicerator
Using a 12-14V power supply the Smart Tray will only consume about 0.1- 0.2A
So, I can use a 12V 10A power supply?
basementLOSI is offline   Reply With Quote
Old 09-23-2004, 01:06 PM   #212
The Evicerator
Yes, that will be fine.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 09-23-2004, 01:22 PM   #213
smyka's Avatar
Send a message via AIM to smyka
hey steve have you played around with bringing the cut off a little bit lower then .09 say like .05 i have noticed a difference in voltage out put on the track i will discharge the pack normally put right before i charge it i bring each cell down to .05 then charge it from their figured i would let you know if you guys want to test some more stuff .. but see you guy in cleveland
smyka is offline   Reply With Quote
Old 09-23-2004, 01:29 PM   #214
The Evicerator
Thanks Mark,
I'll do some more testing again and see if anything has changed from before... if I don't talk to you on here before Cleveland, I'll see you there!!
Steve Weiss
Old 09-23-2004, 06:55 PM   #215
Neil Rabara's Avatar
Steve, thanks for the gold plated units. Goldmember is most appreciative.
Neil Rabara is offline   Reply With Quote
Old 09-24-2004, 09:50 AM   #216
Tim Kowal's Avatar
R/C Tech Charter Subscriber
Default Reverse style packs
My packs are soldered up in a reverse style ie. positive in the left bottom instead of the right bottom. I was wondering if I flip them( the complete pack) over for correct orientation, will the battery bar that is now facing down on the the two ends interfere with tray? How else would I be able to use tray if this does not work? Changing all packs is not an option.
Any help before I purchase tray would be great.
Tim Kowal is offline   Reply With Quote
Old 09-24-2004, 09:58 AM   #217
The Evicerator
We made the smart tray face plate so that would accomodate you flipping your pack upside down with the positive and negative terminal bars facing "down" towards the tray. If you look closely you'll see that the battery cradles for the end cells are different than the center ones.
Steve Weiss
Old 09-24-2004, 10:10 AM   #218
Tim Kowal's Avatar
thanks, what about a jumper wire fitting also for saddle packs? Upside down under the cells in the reverse configuration??
Old 09-24-2004, 10:38 AM   #219
The Evicerator
That's a tough one... it should be able to fit in there ok... if you have a friend with a tray I would recommend seeing if you can get it in easily... if not the clips bend rather easily.. maybe you can work something out?
I'll have to think about that one a little bit more ...
Steve Weiss
Old 09-24-2004, 01:54 PM   #220
Can any one tell me if I understand the following correctly.
When discharging NiMH cells (GP3300) It is recomended to discharge a 6 cell pack down to 5.4v so that you do not take any one cell down to low.
BUT when using the smart tray after you have discharged your pack to 5.4v you should do no harm to your cells by discharging to a lower voltage (eg 0.5v per cell), due to the fact of discharging the cells individually ensures that you should never be able to fully discharge a cell this way, and if you then do not store the cells but charge them an hour or so later.
Steve B is offline   Reply With Quote
Old 09-24-2004, 02:43 PM   #221
V12
V12's Avatar
Yes youīre right here. But I think even after using the smart tray itīs not necessary charging after one hour. Iīm using a different equalizer board but I havenīt found a problem with equalizing a day before charging.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 09-24-2004, 02:55 PM   #222
chr15tophe's Avatar
just bought the novak tray here in the UK was a bit dissapointed to have to solder croc clips onto the wires and to strip the tray down to adjust the clips for the end + and - terminals, but i guess you have to accomadate all sorts of battery configurations, on the good side the colour matches my pro4 nicely and it does a really good job of equilising.!!
chr15tophe is offline   Reply With Quote
Old 10-01-2004, 01:12 AM   #223
safaridog's Avatar
Just wondering if the novak tray will work with 4 cell packs?
safaridog is offline   Reply With Quote
Old 10-01-2004, 01:20 AM   #224
Suspended
yes it will...the instructions state it can work on any size pack from 1 to 6 cells
403forbidden is offline   Reply With Quote
Old 10-01-2004, 06:00 AM   #225
johnbull's Avatar
A smart tray is definately a MUST HAVE.
Since I've be traying my cells I have not had any false peaking.
Another great product from Novak.
Oh,and don't think I haven't had other trays. This one's just streets ahead.
johnbull is offline   Reply With Quote
FS: Novak smart tray , discharger 7HEAVN Australia For Sale/Trade 0 11-27-2007 01:22 PM
Novak Smart Tray Discharger xraycer007 Electric On-Road 1 03-07-2007 05:55 PM
WTB: Equalizing Discharger (IE: Novak Smart Tray,etc) XXWoodmanXX R/C Items: Wanted to Buy 8 10-06-2006 04:32 AM
Novak Smart Tray Discharger John Q R/C Items: For Sale/Trade 8 02-14-2006 08:28 PM
Novak smart tray digital discharger fs sharkman R/C Items: For Sale/Trade 9 03-02-2005 11:00 PM
