Old 07-04-2004, 09:39 PM   #181
ottoman's Avatar
R/C Tech Charter Subscriber
Originally posted by 17driver
What do you mean how do you blame the tray it happened while it was on the tray with one month old batteries.
Ok... I will try to make it simple. The pack that vented was probably raced or cycled and should have been taken down to close to 5.4 volts on a discharger or a T35 etc. before being placed in the Novak tray. If I remember right the max amperage the Novak will draw is 2.7 amps per cell. This is a much lower load on the cell than the race or the discharger after the race. Even if the Novak tray malfunctioned the worse I can see happening is it would take the cells to zero. Neither will cause the cell to vent. The damage to the cell happend before it was put on the tray... or it was put on backwards as mentioned in another post.
Or more likely... the cell just up and died... it happens
ottoman is offline   Reply With Quote
Old 07-13-2004, 09:25 AM   #182
I would like to know if the tray accepts packs with the corally style tubes on the packs? Also, is the positive terminal on the upper left or upper right of the tray? Thanks.
Silvercomet is offline   Reply With Quote
Old 07-13-2004, 09:28 AM   #183
rc-zombies's Avatar
yes...you'll have to adjust the end tabs...
the positive is on the lower right....
Old 07-13-2004, 09:29 AM   #184
Paul_Kultcha's Avatar
Anyone else finds the front face of the tray slides around a bit and sometimes can pinch the botton so it's stuck on? I've had it happen twice and I'm worried one day when I stick a pack on the plastic front face is going to rip the button off.
Paul_Kultcha is offline   Reply With Quote
Old 07-15-2004, 03:14 PM   #185
J-P
J-P's Avatar
hey guys,
just got mine, do you leave the cut off at 0.9 or change it??
many thanks J-P
J-P is offline   Reply With Quote
Old 07-15-2004, 03:16 PM   #186
rc-zombies's Avatar
Originally posted by J-P
hey guys,
many thanks J-P
leave it at .90
Old 07-15-2004, 08:05 PM   #187
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
UNLESS YOU WANT TO DEEP CYCLE YOUR CELLS
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-16-2004, 12:20 AM   #188
J-P
J-P's Avatar
thanks guys i will do that the. untill i got it i didnt realise how uneven the cells got
J-P
Old 07-16-2004, 02:18 PM   #189
17driver's Avatar
Just recieved mine today.
Midwest malitia member
17driver is offline   Reply With Quote
Old 07-16-2004, 05:47 PM   #190
jeepnyy's Avatar
There are at least 5-6 Novak Smart tray for auction on e-bay in the toys & hobbies/radio control section. The bid prices ranges from $51-89.
Henry E.
jeepnyy is offline   Reply With Quote
Old 08-25-2004, 01:27 PM   #191
rayhuang's Avatar
This ones for you Evicerator!! Enjoy!!
Posting and you
Ray
Old 08-25-2004, 07:33 PM   #192
Trader Rating: 23 (100%+)
Posting and you
Ray
Ray, that is the best POST ever!
MDawson is offline   Reply With Quote
Old 09-08-2004, 06:09 PM   #193
Default Maybe A Dumb Question
When you place your battery on the tray, should the battery bars be in contact with the tray contacts ? If not how do you fit your battery ?
Scottymi2b is offline   Reply With Quote
Old 09-08-2004, 06:46 PM   #194
Suspended
Default Did I get a bad discharger?
Ok I just got the tray.
I put in a a Fukuyama saddle pack and it started to heat up very fast in about 2 - 3 seconds. Smoke started to come out so I took the pack out and I noticed one of the cells got damaged (the ink on the label got smeared). I am 100% sure I placed the pack in the tray correctly polarity wise.
Anyhow, I thought it might be a fluke, so I tested a different pack...again a saddle pack. Same thing started to happen...the pack got really hot after 2 seconds, so I had to take the pack out.
What gives? I am sure I placed the pack in correctly polarity wise. No way I would have made a mistake like that twice.
403forbidden is offline   Reply With Quote
Old 09-08-2004, 07:35 PM   #195
The Evicerator
Pay close attention to the polarity of the pack and the orientation of the battery bars:
The positive terminal should be on the bottom right hand corner of the tray, the negative terminal should be at the bottom left-hand corner of the tray.
If you look closely at the front of the tray, you will see little pictures of battery bars...these should line up with the battery bars on your pack.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
FS: Novak smart tray , discharger 7HEAVN Australia For Sale/Trade 0 11-27-2007 01:22 PM
Novak Smart Tray Discharger xraycer007 Electric On-Road 1 03-07-2007 05:55 PM
WTB: Equalizing Discharger (IE: Novak Smart Tray,etc) XXWoodmanXX R/C Items: Wanted to Buy 8 10-06-2006 04:32 AM
Novak Smart Tray Discharger John Q R/C Items: For Sale/Trade 8 02-14-2006 08:28 PM
Novak smart tray digital discharger fs sharkman R/C Items: For Sale/Trade 9 03-02-2005 11:00 PM
