Old 02-28-2010, 04:31 AM   #1
Trader Rating: 4 (83%+)
Default CA Glue Problem
When I apply it, it turns the surrounding areas powdery white sometimes I can remove it. It looks like a burn mark of some sort. What is going no? How can I stop it?
Does it on everything.
DriftWoof is offline   Reply With Quote
Old 02-28-2010, 08:08 AM   #2
sportpak's Avatar
Trader Rating: 26 (100%+)
What brand of glue is it? Typical super glue has a surprisingly short shelf life when it isn't refrigerated. I always try to get the freshest stuff I can find. Look for glue that has an expiration date so you know it's good.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 02-28-2010, 09:36 AM   #3
What are you trying to glue with it? I'd say that is normal on some materials. You can't use CA to glue anything and everything. For an example - no go for Lexan.
lauri is offline   Reply With Quote
Old 02-28-2010, 12:43 PM   #4
Crap, I used it on.... lexan...
A body in fact, what would be a better way to repair cracks?
Old 02-28-2010, 01:50 PM   #5
Regional Moderator
CarbonJoe's Avatar
Fiberglass mesh drywall tape and Shoe Goo.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Learned something new about CA Glue Storage from AE Support Cain Electric Off-Road 23 01-15-2009 01:24 PM
How to remove CA glue? CA Glue on T2R chassis mcgmark Electric On-Road 18 09-27-2006 08:58 AM
ca glue drying time... Johnathan Rookie Zone 19 07-21-2006 08:40 AM
CA Glue on Carbon Fibre TRAJ Electric On-Road 49 03-31-2005 01:40 AM
