Old 02-27-2010, 12:16 AM   #16
gijoe64's Avatar
Trader Rating: 30 (100%+)
crc genxl
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 02-27-2010, 12:42 AM   #17
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Originally Posted by gijoe64 View Post
crc genxl
Nice car, just put my GenXL up for sale moved to Link car.
Should CRC decide to go side shocks I am there.
Am sure the starting rollout will be good, moving from 13.5 to 17.5 will require you going up in rollout as I am sure you know.. 79 for 13.5 is guessing 83-86 rollout in 17.5..
try and locate a duo1 or LRP x12 not saying you will fly past a 13.5 but smooth driving should keep you in the game.
Alex
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 02-27-2010, 01:07 AM   #18
[QUOTE=Me_MrTyson;7063868]Nice car, just put my GenXL up for sale moved to Link car.
Should CRC decide to go link I am there.
r
Alex[/QUOTE
what?crc basically pioneered link cars. the gen xl is a link car.
please explain how it is not.
e-team hobby: www.eteamhobbyplex.com
Fort Collins Colorado
Gorilla Boy Racing
mxzhonkey is offline   Reply With Quote
Old 02-27-2010, 01:25 AM   #19
Me_MrTyson's Avatar
[quote=mxzhonkey;7063923]
r
Alex[/QUOTE
Easy there.... I guess when talking about link to me it mean "with side shock!!" if this is not what that means when talking about X11 Link or Serpent 120 Link I stand correct
Old 02-27-2010, 01:30 AM   #20
fleetmaster's Avatar
Trader Rating: 16 (100%+)
Ouch !!!!
He's running out of manufacturers fast !
I tip : Novak Kinetic or a GM ?
Might I suggest you join mini ? It is, after all , the premier class. Esc and motor are the same Alex.
Then YOU can't blame the equipment !!! BAHAHAHAHAAHAAAAAA !!!!
Good luck mate , I hope this one works for you.
Fleetmeister.
Originally Posted by dangles View Post
whats gonna be the flavour of the week next week alex u need all the help u can get
fleetmaster is offline   Reply With Quote
Old 02-27-2010, 01:50 AM   #21
rack's Avatar
Trader Rating: 65 (100%+)
[QUOTE=gijoe64;7063688]
I am not really an expert on 17.5 only run 10.5 and mod..
In one of the other thread understand could be a team racer said run 60-66 rollout with 10.5
That will be profile 5 and break profile 2.
From someones setup at snowbirds..
43m / 78 spur / 50 pinon = 86 rollout.
What motor are you using? this was based on Duo and un confirmed.
Make sure you check temp's mate.. if the car goes slow or drops off.. gear down a 4 teeth and work back up.
Thanks,
At our track they are running 13.5, and I wanted to de-tune my car alittle. Running 13.5 in my car seems so over the top with the Black Diamond and most guys are over shooting the corners, I want a smoother driving feel so I wanted to try a 17.5 motor but I need to keep up with the 13.5 motors. With a 13.5 my motor temps were 120 deg after 8 min. I will start with a rollout of 79mm our track is not as big as the SB track. Do you guys think I can keep up with a 13.5?
why don't you keep your 13.5 in and add some drag brake it will help you take the turns better
rack is offline   Reply With Quote
Old 02-27-2010, 02:59 AM   #22
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
How many settings are possible? In all of the 'threads' you guys start, you only say to put it at 5 and 2, or is that all you need to do?
1s.........?
2s............?
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 02-27-2010, 03:05 AM   #23
Me_MrTyson's Avatar
1s.........?
2s............?
Settings 5 and 2 is enough to get the BD round the track as this is stock mode, very close to mode 1,8,3,0 on SPX stock spec.
Still need to work out how low is needed for Mod racing, shall work that out in a few weeks.
Should be same for both 1s and 2s as they sell different ESC to cater for both battery types.
Alex
Old 02-27-2010, 04:20 AM   #24
Me_MrTyson's Avatar
Originally Posted by fleetmaster View Post
Ouch !!!!
Fleetmeister.
Have to be honest looked at the GM.. very sweet ESC.
However the BD has a version which 1s small and will make the 120 PORN on wheels
Mini, can I run the BD in Mini otherwise Negative ghost ride the patten is full
Old 02-27-2010, 10:24 AM   #25
gijoe64's Avatar
[QUOTE=rack;7064004]
I wanted to try 17.5 at our track, and if you use drag break on our track you would get run over.
Raymon Robinson
ARC, LRP Go Blue!!
Old 02-27-2010, 10:29 AM   #26
gijoe64's Avatar
Alex
Crc Gen XL is a link car.
Raymon Robinson
ARC, LRP Go Blue!!
Old 02-27-2010, 12:14 PM   #27
Me_MrTyson's Avatar
Gen XL is a link car, and CRC made link cars happen.
120 link and xray II link is also the name of there product.
That is more what I was talking about, the new generation of car called Link.
Old 02-27-2010, 04:01 PM   #28
Me_MrTyson's Avatar
Just to show there is more than setting 5 and 2...
to use drag brake it would be Power profile 5 for stock racing and 4 or 5 to have drag break
Old 03-01-2010, 02:22 AM   #29
Me_MrTyson's Avatar
My BD finally turned up and what a good look esc this is..
There is now a question,
Who out there is using a booster? who out there is taking advantage of option 8.2.
Running 1s this seems like very cool option, you plug your external battery where you normally have jumper pins (5-6) and this boost the power into the RX. If i understand the instructions. Anyone able to confirm before I blow up my new BD
Alex
Black diamond setups P.I.M.P Electric On-Road 78 05-24-2010 07:30 AM
Advanced Electronics Black Diamond Speed Control jrp R/C Items: For Sale/Trade 7 12-04-2009 03:56 AM
CRC / Advanced Electronics Black Diamond Speedo - Ban due to cost?? or8ital Electric On-Road 131 11-30-2009 08:47 PM
Tags
advanced electronics, black diamond
