H.A.R.D. TT3 Tire Truer
Who has one?
What do you think of it? Where can I get one? |
So no one has one?
looks easier than using a screw type lathe. Probably the hudy and others look like this one except they have their motor coverd. I just wished they sold them in the US. Only place i found them was England. Looks cool to me.
I have one.
I think it's great. OK, a little bit more work as you have to push the cutter across, but it does mean you can be very accurate. I have one with a 1/12 arbor. The rear wheels fit very snug, so very good. The front tires have a little play, which means taking some care to make sure the wheel is mounted in the centre before cutting. There is absolutely no play on the cutter and it's sliding mechanism, so I know every cut is the same (and perfect). The only slight downside I have with it, that it only comes with an on/off switch, so to reverse the direction of the drive motor I have to swap the power leads around. For it's low price, I definetely recommend it. |
Originally Posted by J-Racer
(Post 7137798)
I have one.
