Old 04-10-2002, 11:45 AM   #316
psycho's Avatar
AdrianM
Do you guys have 1/12th scale donuts? Maybe I'm blind, but I don't see any.
psycho is offline   Reply With Quote
Old 04-15-2002, 08:17 AM   #317
Ian
i have been reading regarding the Cross F1 and most user has said to encounter oversteer using the inline battery mounting.... currently running stock setting but i have huge understeer...anyone could help me out to give the car to have more steering??i'm running HBR medium front & rear.....should i change to soft front??i prefer not to change the tires ....so what settings would i need to change...my steering servo also seems to be very slow...which servo is best for F1(fast servo)
by the way does a gear ratio of 4.08(94/23) seems good for a Sport Tuned RS540...
Ian is offline   Reply With Quote
Old 04-15-2002, 08:48 AM   #318
Micheal won the grand pre of long beach. It was a great race
teamAE is offline   Reply With Quote
Old 04-15-2002, 03:29 PM   #319
psycho's Avatar
Ian
Ha! Wanna trade cars? I run my Cross car battery in the "Tamiya style" configuration and it still has way too much steering and is horribly twitchy. I'm using a Hitec micro bb servo. Sorry, can't remember the model#. Usually you want to run the softest tires you can get in back and a harder compound up front. When I ran Tamiya HBR tires, I ran mediums up front and soft in back. You can also run purple up front and pink (for asphalt) or grey (for carpet) in rear. I may try red or blue up front, but I'm much faster in my Tamiya car.
Old 04-15-2002, 04:06 PM   #320
Ian
psycho-haha! i'll take yours
Old 04-15-2002, 05:05 PM   #321
Default Sport Tuned Motor
I run a gear ratio of 3.62 or 3.45. So far it is working for me, I have good take of speed and top end. Once you get into the 4 range you motor will start to warm up.
LowBucks Racing is offline   Reply With Quote
Old 04-15-2002, 06:54 PM   #322
Ian
Default Re: Sport Tuned Motor
yes my motor is a lil bit hot.....but i really thought if u gear higher your motor would be hot and warm when geared low....maybe i got it all wrong as i'm fairly new to this rc stuffs
Old 04-16-2002, 11:50 AM   #323
MX3
psycho- tried to PM u but mailbox was full...did u get my email??
MX3 is offline   Reply With Quote
Old 04-16-2002, 12:17 PM   #324
Regional Moderator
Darkseid's Avatar
The lower your final ratio is, the hotter the motor will be. So if you go from 3.45-3.62 up into the 4 area, your motor will actually be cooler.
TLR 22...Tamiya F104...
Old 04-16-2002, 12:39 PM   #325
psycho's Avatar
MX3
"you've got mail"
Ian
You should set your gearing so that you top out on speed as you reach the end of your longest straitaway and tune from there. I race at several tracks and they are always different configurations, so I change my gearing for every race depending on the track layout.
Old 04-17-2002, 03:40 PM   #326
Regional Moderator
Send a message via AIM to Mike F
Originally posted by psycho
MX3
"you've got mail"
Ian
good point pyscho.
I put that P2K2 in my F-1. 100t spur with a 19T pinion. pretty fast but it will be interesting to see if my 2000 battery packs will last 5 minutes, since they've been running with the RS 540 motor
Mike F is offline   Reply With Quote
Old 04-18-2002, 06:20 AM   #327
Ian
ok now my cross is oversteer not sure what causes it but i change the ride height/spring position on centering plate.....just by doing these 2 adjustment it has become oversteer.....ok for now i know i need to change the rear tires to HBR soft...anymore ideas guys???i prefer to work from an oversteer car i find it's easier to lose some traction than looking for more traction.....by the way any cross user out here wanna share some setups that u guys are running
thanks
Old 04-18-2002, 11:53 AM   #328
psycho's Avatar
Ian
Unfortunately, the only way I have found to fix the oversteer problems with my Cross car is to race my Tamiya F103. I run 3.5mm ride height and it is way twitchy, even with 15 degrees of caster. I don't have a good answer for you. I think that running reds or blues up front will help a lot, but I'm not sure if you will be able to carry as much speed into a turn. I may try that once I feel comfortable about scratching a race to experiment. Try turning down your dual rate or using steering exponential (if you have it.) Neither of those things made the car feel right on the tracks I race at.
Old 04-25-2002, 03:24 AM   #329
Ian
anymore cross owners has setups tips to share??
anyways if my f1 doesnt turn hard enuff...or maybe a lil slow in reacting to a turn ...does by changing to a faster servo help??or can i try to change setups??what is a fast servo for F!??
Old 04-25-2002, 06:06 AM   #330
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
IAn, I dunno what to tell ya, I run Tamiya rubber tires and the car works great for me.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
