Old 03-18-2010, 09:21 PM   #46
Trader Rating: 42 (100%+)
needs to be on top
KEITH is offline   Reply With Quote
Old 03-18-2010, 09:27 PM   #47
Right on if anyone has any other questions about setup on cars or anything feel to ask
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 03-18-2010, 09:31 PM   #48
defcone's Avatar
Trader Rating: 15 (100%+)
A 10.5 1/12th rs setup? Just need a starting point as I'm new to tekins.
Small-medium track with a 20 meter straight.
Thanks in advance.
defcone is offline   Reply With Quote
Old 03-18-2010, 09:33 PM   #49
Thanks in advance.
whats the width
Old 03-18-2010, 09:38 PM   #50
defcone's Avatar
whats the width
Around A meter and a half
Old 03-18-2010, 09:41 PM   #51
The whole track width not the lane
Old 03-18-2010, 09:50 PM   #52
defcone's Avatar
My guess would be around 20x30m.
Old 03-18-2010, 09:59 PM   #53
throtle profile 5 2400 to 7000 rpm ramp 2.0 ramp rate 40 boost turbo 5 to 10 .1 delay 38pinion 76 spur start there. Should be a safe setting Check motor temp after 4 minutes. This would be starting point but im not a 100percent sure cause i havent run a 10.5 on that small of a track
Old 03-19-2010, 02:45 AM   #54
revsinc's Avatar
Is there a Data base of esc settings anywhere ??
thanks
Full Speed , Half Price
revsinc is offline   Reply With Quote
Old 03-19-2010, 08:26 AM   #55
Default 24' x 40' Bull Ring Setup
Jeff, what would be a good starting point for a 17.5 Redline in a 12th scale pan car on a track this small. Lanes are tight, about 6'. There is a sweeper on to the straight and another at the end of the straight effectively giving us about 60' of WOT. The infield is quite tight and technical.
Another questions would be in regards to the different rotors that Tekin has available, what do you gain or lose by switching rotors in a 17.5 motor?
Thanks,
Bob
Bobinmt is offline   Reply With Quote
Old 03-19-2010, 08:46 AM   #56
tc3team's Avatar
thanks
there should be some here for your application:
http://www.teamtekin.com/hotwire/ESCsetups/index.html
hope that helps
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 03-19-2010, 09:26 AM   #57
Trader Rating: 16 (100%+)
You loose boost after 6 minutes?
No...motor probably getting warm and hot, and get SOFT...almost everyone does.
Old 03-19-2010, 05:32 PM   #58
Thanks,
Bob
I would be around 76/48. Lower turbo and keep all the other settings the same as the setting i posted already. Run mid timing on the motor.
Old 03-19-2010, 05:47 PM   #59
Jeff....do you have any Scotty's TRACSIDE setup for 17.5 and 13.5 TC? Thanks...
Old 03-21-2010, 10:34 PM   #60
i would start with what i currently posted. Start there let me know how u make out. Let me now motor temp and fall off through out the run
