Old 02-24-2010, 10:05 PM   #16
Originally Posted by tandman View Post
Cool, thanks Jeff I will let you know how it goes.
Sounds good glad I could help out
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 02-25-2010, 06:37 AM   #17
jkirkwood's Avatar
Originally Posted by Jeff Cuffs View Post
78/50 1.70 tires.
Thanks, I'll see how this goes next time I'm at Tri-State, that is if I can get back up there. Seems every week something comes up.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 02-25-2010, 06:55 AM   #18
Trader Rating: 19 (100%+)
Jeff,
Do you have a setting for 13.5 touring rubber? Also your FDR?
Thanks!
zake540 is offline   Reply With Quote
Old 02-25-2010, 07:49 AM   #19
san.'s Avatar
Trader Rating: 60 (100%+)
Thx, Jeff.
Awesomatix USA||Roche RC USA||Mon-Tech Racing USA||Sanwa
san. is offline   Reply With Quote
Old 02-25-2010, 11:08 AM   #20
Originally Posted by zake540 View Post
Jeff,
Thanks!
I was at 7.30 at the birds for 13.5 rubber with the same settings as my 17.5 tc.
Old 02-25-2010, 11:09 AM   #21
No prob yeah keep me posted
Old 02-25-2010, 11:10 AM   #22
Originally Posted by san. View Post
Thx, Jeff.
No prob anytime. Have any other questions feel free to ask.
Old 02-25-2010, 07:31 PM   #23
Thanks! Gonna try it this weekend.
Old 02-25-2010, 08:27 PM   #24
Sounds good
Old 02-27-2010, 09:49 PM   #25
Trader Rating: 42 (100%+)
hey jeff tried your set up, got me real close. i might take out some boost
thanks alot for the help
KEITH is offline   Reply With Quote
Old 02-28-2010, 04:10 AM   #26
Trader Rating: 16 (100%+)
Jeff...do you remember the size of the snowbird track..? I want to compare that size vs our local track or the several tracks that I usually go, and adjust the turbo ramp, the start end RPM from your setting accordingly....for 13.5 and 17.5 TC rubber.
Also, your 13.5 17.5 rubber TC...both motors are Duo 2 base or Duo 1 base..?
Thanks.....and this thread should rename to "Ask Jeff Cuffs about anything.."
Old 02-28-2010, 06:24 AM   #27
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
It was like 96X40
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 02-28-2010, 10:20 AM   #28
What was your motor temp after 8 mins? How much did your car fade lap times wise start to finish?
Old 02-28-2010, 10:25 AM   #29
All the motors I'm running are currently duo 1 based motors. The duo 2 seems like it needs alil more motor timing to run with the duo 1s. Yeah I think it was 96 x 40 or 42. You guys running 5 or 6 minutes. Might have to lower boost a bit if your running 6 to control temp. I run a fan behind my motor on all my touring cars. I would run those settings without one.
Old 02-28-2010, 07:34 PM   #30
jeff motor was 105 to 108 after 7 to 8 min. rolled around 3.0 could use a little more torque was a duo 2 17.5 ea tuned
