motor assembly
Old 02-22-2010, 05:32 AM
Default motor assembly
i have a motor the gear that goes on it and the screw that holds the gear. ive got it so that the gear turns the shaft but how do i keep the gear from sliding off the end of the shaft.
if u could post a video of a motor being assembled that would be great if not oh well.
\btw its going on an xxx-s
rustlerkid is offline
Old 02-22-2010, 07:55 AM
sosidge's Avatar
The set screw that holds the pinion in place should grip well enough to stop the gear sliding off.
If it doesn't then there must be a problem with the parts being worn or damaged somehow.
sosidge is offline
Old 02-24-2010, 05:30 AM
i figured it out i didn't use an alen wrench to tighten it (i didn't know was sposed to) but i tightened it and it aint going anywhere now.
thanks anyways
Copyright İ 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
