Old 04-03-2004, 10:29 AM   #1
Registered User
JonteJsson's Avatar
Default Power a lathe ..
Hi!
I am going to buy a comm lathe ...
I wonder if I have got to use a 4cell battery pack or can I power it with my power supply??
Regards/ JonteJsson
JonteJsson is offline   Reply With Quote
Old 04-03-2004, 10:33 AM   #2
Send a message via AIM to True R/C Racing
u can use a power supply if its like 2-4Volts. A 4 Cell pack should be fine though. HOpe this helps
True R/C Racing is offline   Reply With Quote
Old 04-03-2004, 10:36 AM   #3
Send a message via AIM to A-Ko
4 cell pack works perfect.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 04-03-2004, 10:36 AM   #4
Registered User
JonteJsson's Avatar
Yeah that helped me very much ...
Old 04-03-2004, 10:47 AM   #5
Regional Moderator
Send a message via AIM to Mike F
what kind of charger do you have? If you have something like the LRP competition charger, you can use that to power a lathe
Mike F is offline   Reply With Quote
Old 04-03-2004, 11:39 AM   #6
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
If the instructions ask for 4 cells to power your lathe, you can get a power supply to supply not more then 5v. It must be able to provide 5 amp of supply
Hope it helps
AdR|aN is offline   Reply With Quote
Old 04-03-2004, 10:18 PM   #7
Registered User
JonteJsson's Avatar
I have not got a good charger ... Yet .. Ill buy the compeition in the beginneing of the summer or maybe earlier ..
Old 04-04-2004, 09:15 AM   #8
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I use my Pulsar Comp at 7.2 volts or 6 cell pack.
Works fine with the motor that was with my Hudy lathe
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 04-04-2004, 10:01 AM   #9
Registered User
JonteJsson's Avatar
Then if I put a stock motor in my lathe .. I can power it with my usual 3000/3300 accus !?
Old 04-04-2004, 10:41 AM   #10
popsracer's Avatar
Default if I put a stock motor in my lathe
JonteJsson;
You can use a Stock Motor for a Lathe drive Motor. Much, faster than you need to turn the Arm for cutting. You might want to go with a 3 cell pack or (3.6V) to keep the rpm's down.
Otherwise, there are companies that sell high turn slave Motors just for Lathe applications.
What does everyone else think?
popsracer is offline   Reply With Quote
Old 04-05-2004, 04:46 AM   #11
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
Contact Banzai Motors and get them to wind a 80 x 1. You can power it with you 12 volt supply and it is perfect. You just adjust the timing to fine tune the RPM range you want.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 04-05-2004, 08:10 AM   #12
John Fontaine's Avatar
Send a message via AIM to John Fontaine
Where have I heard that before??
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 04-05-2004, 09:49 AM   #13
jaysimpson's Avatar
LOL, Yeah I wonder
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 04-05-2004, 10:15 AM   #14
Default Stock motor works great
I use an OLD stock motor, it has to run backwards for my lathe, so it runs pretty slow on 4 cells. I like 3 cells better, but 4 works fine. Integy makes a 55 turn lathe motor for 12 volts, the 80 turn posted earlier is also good. I am too cheap so I just use my crummiest stocker and a 4 cell pack.
I also have a 5 volt tap off my computer power supply I use for my chargers. This works great also.
David Root
David Root is offline   Reply With Quote
Old 04-05-2004, 11:43 AM   #15
jaysimpson's Avatar
The problem with the 55t is still doesn't produce the quality of cut the 80t does because of the smoothness of the 80t. The key to the 80t is it runs so smoothly and causes less vibration in the lathe.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Cobra Com Lathe w/ Power Feed. TheTurtleMan R/C Items: For Sale/Trade 14 04-25-2007 04:24 PM
Twister Com lathe w/ power pack and diamond bit dyoung R/C Items: For Sale/Trade 1 11-19-2005 07:07 PM
Power supply for lathe? Galactik Electric On-Road 7 09-23-2004 10:31 AM
For Sale : Com Lathe w/ power base ZeroCooL R/C Items: For Sale/Trade 11 08-19-2004 04:15 PM
Power a motor lathe from any charger?? G-spec Electric On-Road 9 05-21-2004 02:16 PM
