Old 02-24-2010, 04:03 PM   #46
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Ok so we get you are a Tekin fan think we all get that lots of people out there are.
However personally purchased at BD because I can afford to run one.
This forum was labeled "Black diamond setups", Belive Tekin have there own forum where you can tell people how much you like it there.
Visit this forum looking for advice on how to setup the BD not worry about how much it cost or how wonderful Tekin 203 software is..
I run 1/12th scale with a LRP x12 10.5 running timing oooo.. What kinda rollout would I need as a good starting point on a small / medium none carpet setup.
Frank or AE driver would be nice to get some assistants
Alex
Originally Posted by mikky32 View Post
for what I have seen here ad the moment and as I hear the drivers around here, The BD is way to expensive.
Also that you can't update it your self is a problem bud the biggest problem is, is that it's not available out here or you must buy it over seas.
Yes I now how to setup the Tekin bud it isn't that hard.
And as Tekin comes with the things that they want, than you can setup ad home the profiles and you don't need a laptop on the track.
I use now the same setup on every track I drive indoor. I only change the gearing.
I looked ad the BD my self, bud when Tekin came with the V203 it was over.
The BD is to expensive for me and a lot of other drivers.
That is there biggest loss ad the moment.
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 02-24-2010, 07:46 PM   #47
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I know most are doing this so lets continue to keep this a discussion about the Black Diamond speed control. Thank you.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-25-2010, 04:43 AM   #48
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
I think discussion on the bd is good but this thread was intended for setups so if anyone can help a racer with that please don't let it go unheard.....OK about the bd i think some one mention it before about the bd is good on smaller tracks i would say there 100% correct with the testing i did with 17.5 on a smaller track the bd has it all over the tekin 203v but on a larger tracks i personally think the tekin will come out on top the bd seems to run out of puff before the tekin but the bottom end on the bd seems to keep the tekins at bay''for now''.i would like to see there be somewhat of a firmware upgrade for the bd soon because with the spec class speedy are out dated so fast unless there upgradable.
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 02-25-2010, 06:29 AM   #49
Alex
2.45-2.60
I ran 2.6 at snowbirds with a Trinity Duo 1 10.5
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 02-25-2010, 08:29 AM   #50
rack's Avatar
Trader Rating: 65 (100%+)
I have a low profile one on the way. I would like to know if I can get away with use the speedo bec or will I need to get a li-fe pack or booster.
rack is offline   Reply With Quote
Old 02-25-2010, 10:23 AM   #51
gijoe64's Avatar
Trader Rating: 30 (100%+)
Does anyone a 17.5 1/12 set up for this esc? I run on a med size track.
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 02-25-2010, 01:08 PM   #52
Me_MrTyson's Avatar
Originally Posted by dumper View Post
2.45-2.60
Dumper,
Thanks for the starting point. 60-66 rollout
Just spent 10 minute working out what Spur I can use
Is there a starting point for Mod racing, would be anything from 3.5 t- 4.5t, I like to run very quick
Seem you could be the person to ask if you have any info on the update / updated software.. This is a good forum as any to start / brake rumors
Thanks for the help
Alex
Old 02-26-2010, 09:53 AM   #53
Me_MrTyson's Avatar
Seems to have gone quite!!!
My BD still in the post.. However the SPX on profile 7 worked well tonight
Old 02-26-2010, 12:09 PM   #54
corallyman's Avatar
Trader Rating: 99 (100%+)
You know, if you really want to keep this thread on the straight and narrow you might want to refrain from saying " the BD has it all over the Tekin v203". You are just inviting the type of discussing that you claim you want to avoid.
Jeez, Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 02-28-2010, 01:09 AM   #55
P.I.M.P's Avatar
Jeez, Steve
well guys done some more testing today with 17.5 with the bd along side a fast 203v tekin and there was no differences in top end but the bd had a better bottom end so if your keen on spending about $200.00 us more then its up to you there is not much between them
Vbc wildfire D06
clinton livingstone
Old 03-04-2010, 03:06 AM   #56
rack's Avatar
I just got my bd today the esc is great fast and very easy to set up. I had a rs but I like the bd it has a much better low end but around the same top end.
Old 03-04-2010, 04:41 PM   #57
P.I.M.P's Avatar
Originally Posted by rack View Post
I just got my bd today the esc is great fast and very easy to set up. I had a rs but I like the bd has much better low end but around the same top end.
Good to see your findings are the same as mine
Vbc wildfire D06
clinton livingstone
Old 03-04-2010, 06:18 PM   #58
Clint
good to see that you have found a speedy that you can setup.
easy to setup is the go. best of luk with the DB.
Steven.
Casino Kid is offline   Reply With Quote
Old 03-05-2010, 06:50 AM   #59
Dumper,
Thanks for the help
Alex
For mod (3.5-4.0) Profile 1 with a rollout around 1.35. Higher profiles are faster, but are harder to drive and generate more heat.
I work for CRC and have alot of experience with the Advanced speed controls, including the brushed unit, so I will answer what questions I can.
Brian Wynn
Team CRC
Old 03-05-2010, 06:51 AM   #60
Around 2.79 depending on motor on profile 5.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
~~757Holeshot Garage Sale- T-Maxx, Sportwerks ST, BL, 19T, RC DVD, Charger~~ fav0re R/C Items: For Sale/Trade 12 08-07-2007 02:12 PM
