LRP SXX TC Spec perfect setting. >
Old 02-20-2010, 08:49 AM
Viruz408's Avatar
Lightbulb LRP SXX TC Spec perfect setting.
Tips to set sxx tc spec using stock or modified brushless motor.
Viruz408 is offline
Old 02-20-2010, 09:03 AM
Viruz408's Avatar
I'm using Lrp stock speck 10.5t on sxx tc spec at trf416we.
(Mode 2) Which power profiles should i use?
(Mode 3) which initial brake shud i use?
(mode 4) which auto brake shud i use?
Im using pinion 37t. Is it ok?
My motor been chase by 11.5t speed pasion motor. Got confuse why it cud be dat way. Haha
Plz give me some tips to set.
Viruz408 is offline
Old 02-20-2010, 09:10 AM
Akudou's Avatar
Raise your pinion to 39t and check your temps. then gradually go up one tooth as you check your temps every 5min run... the 11.5t is a team powers and not speed passion..
Akudou is offline
Old 02-20-2010, 09:20 AM
Viruz408's Avatar
Default Wil try it on.
haha u noe it geng.. Tongking pun berasap.. Bajong motor wasnt speed passion 11.5t ka?
Viruz408 is offline
Old 02-20-2010, 10:07 AM
Viruz408's Avatar
Default Sxx tc spec user.
sum1 if use sxx tc spec plz do reply.
Viruz408 is offline
Old 02-20-2010, 12:47 PM
harry_mcoe's Avatar
(Mode 2) Which power profiles should i use?use 10 if u run stock(malaysia run 11.5 jer bro...go t0 team power motor(prefer adjustable timing) to matching with this esc..gerenti ummppphhh
(Mode 3) which initial brake shud i use? use 0 profile
(mode 4) which auto brake shud i use? use 0 profile
hope this will helps u bro...go go go TRF 'n' BLUE IS BETTER
harry_mcoe is offline
