What to get
Old 04-02-2004, 03:26 PM
Crashmaster's Avatar
Default What to get
I currently have a TC3 Racer racing in semi-competative mod class. What do you guys think I should get:
A BMI racing chassis to replace the stock composite one
or
A new charger to replace my fixed delta peak 4A charger
Sorry if this is a pointless question, but I am really clueless.
Cheers
Crash
Crashmaster is offline
Old 04-02-2004, 03:41 PM
J-P
J-P's Avatar
hey,
personaly, when i wanted "take the next step up"!! i found that a real good charger and cells really helped and i did notice the differance and so did other people, personaly i use the LRP comp as do most people i race with but thier are lots of good one's on the market, hope this helps?
J-P
J-P is offline
fatdoggy's Avatar
Definately the charger. A good charger is the most important thing to invest in, if you intend on staying in the hobby.
fatdoggy is offline
Old 04-02-2004, 03:45 PM
Cheers guys, thats what i fought. Now where's that money...
Cheers
Crash
Old 04-02-2004, 03:52 PM
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: What to get
or
Cheers
Crash
get a really good charger (i.e. Turbo 35GFX, futaba CDR-5000) because your car can be set up by the best of them... but if your batteries arent charged right, you chances of winning will decrease. there is a noticeable different between charging at 4amps and 6amps. good luck in your decision making!
Hebiki is offline
Old 04-02-2004, 04:35 PM
crimson eagle's Avatar
The TC3 is not a bad car at all. From what I read the limiting factor right now is not the car's ability, but your ability. As you improve you may get to the point where you feel the car is restricting your improvement but I don't think that you have reached that point yet. However you could talk to one of the other drivers who have more experience to look at your car and make suggestions about improving what you have, probably for not too much money.
A charger is a great investment and a good one will stay with you forever (please don't forget about the Pro Trak), but the only thing that will help you to improve is practice.
Dusty.
www.pro-trak.co.uk
crimson eagle is offline
Old 04-02-2004, 04:40 PM
DT-Skyline's Avatar
Get charger fisrt cuz how are u going to use the car without any charger? After that, get a BMI Chassis, once u get the money.
DT-Skyline is offline
Old 04-02-2004, 04:42 PM
Hebiki's Avatar
Dusty.
www.pro-trak.co.uk
my bad Dusty! the ProTrak is another high end charger thats received a lot of great reviews.
Hebiki is offline
Old 04-02-2004, 06:02 PM
I just got a Indi 16x7v6....very happy with it. Simple to use and has a lot of kick-ass features. Integrated Power Supply AND DC hookup, adjustable milivolt settings, battery conditioning (displays adverage voltage of the pack, you can compare your packs to see which one goes to the mains) 30 AMP discharge, 6.5 AMP charge and manageable size (I'm forced to walk/transit to the track 60 miles away so size/compactability is a must) Good charger for the long run
BUT....I do reccomend the BMI chassis. I got one and its sweet. Lightens the car a bunch while stiffening it up and a nice motor mount system
OOC: What kinda of gear are you running in the car? A good, high amperage speed control is a must. Same with a good set of GP's
The Black Kat is offline
Old 04-02-2004, 06:29 PM
Neil Rabara's Avatar
or
Cheers
Crash
The charger is more important. There are alot of people still racing the original chassis.
Neil Rabara is offline
Old 04-02-2004, 06:36 PM
Default what you should get.....
get a new charger that way youll have no problems getting your batts up to racing spec's .. then as you feel it necessary get a new chassis (BMI) . That will give you an edge when your ready for Real compition .. sounds like your on your way . so good luck and have a great time at racing.......
mb racer is offline
Old 04-03-2004, 03:37 AM
Cole Trickle's Avatar
Yep, a good charger is a must. Your batteries deliever, what you put into them So the better you put in...
Cole Trickle is offline
