Question about  Novak-smart boost- TQ cells and any other company >
Old 02-18-2010, 10:35 AM
Default Question about Novak-smart boost- TQ cells and any other company
I know my Novak smart boost will not work properly with the new Tekin ESC. I've heard about the TQ cells booster? I've also heard about another company that makes a booster like a TQ cell type. I don't want to run a reciever battery anymore.And My novak smart boost won't work right- any suggestions?
BullFrog is offline
Old 02-18-2010, 10:58 AM
Company Representative
Originally Posted by BullFrog View Post
I know my Novak smart boost will not work properly with the new Novak ESC. I've heard about the TQ cells booster? I've also heard about another com,pany that makes a booster like a TQ cell type. I don't want to run a reciever battery anymore.And My novak smart boost won't work right any suggestions?
What Novak esc are you describing, and what seems to be the problem?
NovakTwo is offline
Old 02-18-2010, 01:23 PM
Ops- I meant Tekin- but I'm waiting on the new Novak. It works on the bench but on the track it sputters and that just in the warmup session before the race.
BullFrog is offline
Old 02-18-2010, 01:30 PM
I have forwarded your comments to engineering.
NovakTwo is offline
Old 02-18-2010, 02:12 PM
chris moore's Avatar
Trader Rating: 93 (99%+)
Its not the Tekin esc persay but the newest software that Tekin released(V203) where everyone is haveing issues when running the boosters. In reading the 1/12 thread just today a couple of racers have reported that this boosterhttp://www.rctech.net/forum/7022846-post33571.html is working fine with the new software; I'm going to take a look at it as I dislike a rec pack also. I've had no problems with the TQ booster on V200 running a 13.5 and I've been running that booster for 6 months or longer now, but I have'nt updated to V203 because of the problems that have been reported.
chris moore is offline
Old 02-18-2010, 03:12 PM
Novak 2- I should also include that it sputters so bad you can not race.I went to my old reciever pack but I pulled it off after the race.I could go to the new Tinity reciever battery but I don't want to.
BullFrog is offline
Old 02-19-2010, 02:44 AM
GasGod's Avatar
I run a smartboost on an rs w/v203 1s 5000 13.5 and no prob.
Maybe I'm lucky-- so far.
GasGod is offline
Old 02-19-2010, 02:49 AM
tc3team's Avatar
I wonder if it's an issue only with smaller capacity/burst rated lipo's?
Probably unlikely, just throwing it out there for discussion...
tc3team is offline
Old 02-19-2010, 05:40 AM
GWH74's Avatar
You will find that it is the current surge / spike from the motor that is tripping the novak lipo cut-out.
You could try adding a bit of current limiting on the Tekin v203. This should should stop it.
I am not sure if you can disable the current limiting on the novak. I will have a look at a fellow racers on the weekend. But if you can disable the cut-out ensure that you use the lipo cut-out in the tekin or at least time you usage.
GWH74 is offline
Old 02-19-2010, 06:54 AM
Trader Rating: 16 (94%+)
The problem with the Novak Smart boost is the Built-In Cutoff Voltage at 3.3 Volts. With the new Tekin 203 software, the ESC's are putting a much higher load on the battery, and when those peak draws occur, the battery voltage easily dips below 3.3 Volts for a few milliseconds, which was confirmed using the Novak Sentry logger.
Once the battery gets to the lower end of the available voltage on the battery, you can reproduce the Novak Smart Boost LiPo Cutoff circuitry kicking in on the bench with a few quick burst of full throttle.
The solution for me has been to either run lower gearing to reduce load on the battery, or by running a reciever battery.
Im WGT 13.5, the cut-off problem I experienced was more prominent. I figured this was because the car was heavier than 1/12, so full throttle on the track created more load to move a heavier car, and by 3-4 minutes into the race the Novak Smart Boost wouldn't let me complete a lap.
In 13.5 1/12 I don't start experiencing the issue until about 5-6 minutes into the race, then I can't use full throttle at all. Gearing down, smaller pinion, helped this condition. To Note, when we started using the Tekin 203 software, we immediately started using about 500mah more power out of the pack during an 8-minute run.
In 17.5 1/12, I can use the Novak Smart Boost the entire race regardless of my gearing.
Novak - Is there a way to disable or lower the Built-In LiPo Cut-Off on the Smart Boost?
kn7671 is offline
Old 02-19-2010, 07:20 AM
I'm using Thunder Power 5000 40C packs, and we have heard of others with SMC 5000's having the issue too.
kn7671 is offline
Old 02-19-2010, 08:02 AM
Tech Legend
Cain's Avatar
Trader Rating: 268 (100%+)
as a side question, what is the cutoff set at for the TQ Boost and is the white version with the switch the latest version of the TQ Boost?
Cain is offline
Old 02-19-2010, 08:21 AM
Thanks for this overview; it should be very helpfull. I am forwarding your comments and question to engineering.
NovakTwo is offline
Old 02-19-2010, 08:23 AM
tc3team's Avatar
ah ok, I had a quick shot guess!
tc3team is offline
Old 02-19-2010, 08:27 AM
We noticed the same issue in GT10's running 1S Lipo on Tekin v203 with the novak booster. No problem with v200, but apply v203 and the cut off kicks in at full throttle, giving you no throttle at all until the motor coasts to a speed slow enough (almost stopped)
Changed to a tq booster or an rx pack and the problem's gone.
Didn't seem to matter which lipos/motor either by the way
chris_dono is offline
