Downtravel, what's a good starting point? >
Old 04-02-2004, 05:04 AM
Cole Trickle's Avatar
Default Downtravel, what's a good starting point?
What's a good starting point for amount of downtravel?
I'm running in stock class, carpet (with a few small bumps), rubber tires and a HPI Pro2
I know for sure the info already is on this forum, but I couldn't find it
Cole Trickle is offline
Old 04-02-2004, 05:42 AM
sosidge's Avatar
I would say 2mm "real" droop all round as a good starting point.
sosidge is offline
Old 04-02-2004, 01:58 PM
Speedie's Avatar
I range from 1-2 in the front and 2-5 in the rear with rubber tires.
Thats downtravel not droop.
Speedie is offline
Old 04-02-2004, 02:01 PM
my thoughts to
R/C Anonymous is offline
Old 04-02-2004, 10:04 PM
DT-Skyline's Avatar
Get some foams for carpet. Save your rubber tires when playing outside.
DT-Skyline is offline
Old 04-03-2004, 09:07 PM
popsracer's Avatar
Cole Trickle;
Usually for outdoor Asphalt, my Cars work better if I run full droop.
Since the traction on Carpet is so good, you may need to limit droop to get the fastest possible lap times.
Start with 4-5mm in the Front and 5-6 in the Rear. This will make for a very stable Car and you can always take some out later if needed.
popsracer is offline
Old 04-03-2004, 09:21 PM
fatdoggy's Avatar
Some tracks are rubber only and some are foam only. It all depends on where you are.
fatdoggy is offline
Old 04-04-2004, 11:17 AM
popsracer's Avatar
That's right! I remember seeing Rubbers on YOUR Car the last time you were playing outside.
Hope Nate left some parts on the Car when he gave it back to you.
Old 04-04-2004, 11:50 AM
We're only allowed to use rubber.
Today I went from approx. 5 mm downtravel to 2. Way more responsive, yet good grip AND stable. Actually, it's very stable during cornering.
However, the rear tend sligthly to (very sligthly) to spin a little out. I think I try 3 mm all around next time.
Thanks for your help.
Old 04-04-2004, 06:10 PM
MrEs's Avatar
the rear should have more droop then the front, ie
2,4
3,5
MrEs is offline
Old 04-05-2004, 07:52 AM
JohnA's Avatar
Could someone clear this up for me?? My droop guage looks like this:
I would have thought more droop would have meant longer shocks or more down-travel. Using a guage like this it is actually the reverse????
File Type: bmp
JohnA is offline
Old 04-05-2004, 08:38 AM
Registered User
Pyramid's Avatar
So what is the different between those two? I know what a down stop is..
A good starting point is to have front and rear the same... AT WHAT NUMBER?? Just be sure on Max droop, the spring still being hold firm enough with its collar and end cup. That's the starting point!!
Pyramid is offline
Old 04-05-2004, 09:24 AM
sosidge's Avatar
It's a bit confusing innit John?
Strictly, more downtravel IS more droop.
The gauges are made in such a way that more droop is actually a smaller number.
I suppose it's a result of them referencing from the bottom of the chassis - it's easier to use that as 0, than to use it as 10 and then count down.
As long as people don't confuse "gauge" measurements with "real" measurements, and state how they are measuring it, there shouldn't be any confusion
sosidge is offline
Old 04-05-2004, 10:19 AM
JohnA's Avatar
Cheers Sosidge!
That's what I thought, but as you say it can be confusing.
JohnA is offline
