Screwed-UP
Old 04-01-2004, 11:55 PM
JayBee's Avatar
Trader Rating: 31 (100%+)
Default Screwed-UP
I just bought a Yoke MRTC-SD SSG and bought the titanium screw set and read somewhere recently that a galvanic action (a sort of chemical reaction that induces welding of the two materials together) happens. There is a few aluminum parts with this kit and I bought a few more. Should I just avoid using the ti-screws when going into the alum. parts and use the stock screws?
PLEASE.....help a brother out
JayBee is offline
Old 04-02-2004, 12:44 AM
WC
WC's Avatar
Trader Rating: 28 (100%+)
Only could happen when there's identical materials eg Ti screw into Ti component, or Al into Al. The 2 components could "weld" themselves together.
You avoid it by putting a barrier between them, like grease or threadlock.
Ti into Al should be ok.
(If its a screw into-metal that doesn't need taking out regularly, I'd threadlock it anyway... )
WC is offline
Old 04-02-2004, 04:36 AM
sean's Avatar
i wouldnt worry about any galvanic corrosion unless you plan on putting pontoons on your car and using it as a boat. but you are right-disssimilar metals will react quicker(under the right circumstances) one metal becomes the "cathode" (titanium,because its harder) and the other(aluminum) becomes an "anode" and will begin to pit and corrode.but again unless you race you car under salt water it wont happen. oh and BTW thread lock is a corrosive and damages aluminum
sean is offline
Old 04-02-2004, 05:07 AM
1fastdude's Avatar
Trader Rating: 16 (100%+)
JayBee where did you get the Titanium screw kit? Do they have kits for other cars also?
1fastdude is offline
Old 04-02-2004, 07:00 AM
JayBee's Avatar
Default Tt-sets
whew, thanks for the info guys.
I got mine from ultimatehobbies.com, you won't be able to order it via the net so call them.
speedtech.com or precisionrc.com also has them. Any problems with these sites, give me a holler.
again thanks guys and good looking out with the threadlock thing.
oh, almost forgot, when starting to thread your turnbuckles should i use dishwashing liquid or lightweight oil to make things a little easier?
JayBee is offline
Old 04-02-2004, 07:33 AM
John Fontaine's Avatar
You'll still see the welding action from Ti to AL. I suggest you put a bit of grease on the screws before you assemble. It would suck to loose the screw and bulkheads if this happens!
John
John Fontaine is offline
Old 04-02-2004, 09:54 AM
WC
WC's Avatar
Default Re: Tt-sets
try candle wax, lot less messy.
WC is offline
Old 04-02-2004, 09:59 AM
WC
WC's Avatar
There are 101 types of threadlock, even Loctite has dozen different types...
I use Tamiya's Threadlock (its a solvent glue) and also Loctite or Permatex anaerobic products (which cure only when there's no air).
Do not buy "permanent" threadlocks nor the etching types too.
Some silicone sealant is also corrosive (acidic), try to use only "neutral cure" type RTVs.
WC is offline
