better touring car tires
when you are get a new set of tire of on road 1/10th touring car they will have a glossy shine on the tire and that will make you have less grip on the track to take of that shine you get a small file to rub off the glossy shine after you have filed the tire the should be no more gloss shine if there still is file is again.
Not a good idea. The shine is just superficial and goes away after just a few laps (which it takes anyway to warm up the tires if you don't have a tire warmer). I think you can do more damage than good with your idea.
I take mine out for a few gentle laps to take the shine off of them, works for me
Don't go racing round the track, use the time with new tyres as a feeler for the track and learning where the sharper corners are so when they are up to pace, you will have remembered where the braking areas are.
The shiny surface disappears quickly, but the blurr in the center of the tire doesn't. I always remove it, even for practice tires.
