Tc3 Chassis Drawing.. >
Old 04-01-2004, 11:50 AM
Registered User
JonteJsson's Avatar
Default Tc3 Chassis Drawing..
Someone got a pdf or gif or something similar with all messures on the chassies .. Want it to make me a carbon chassi for meself .. Nothing to sell just want to have it and print and cut out on a bit of carbon ..
Thanks to whoever helps me ..
//JonteJsson
JonteJsson is offline
Old 04-06-2004, 11:22 AM
SammyXp's Avatar
Here's a quick one. Dimensions should be within .010", but no gaurantees.
SammyXp is offline
Old 04-06-2004, 04:56 PM
GO SAMMY!
True R/C Racing is offline
Old 04-06-2004, 11:14 PM
Registered User
JonteJsson's Avatar
Thumbs up Thanks..
Thanks alot .. Just one hour of translation to centimetres ..
Old 04-07-2004, 12:27 AM
TC3Racer67's Avatar
wow
TC3Racer67 is offline
Old 04-07-2004, 07:00 AM
SammyXp's Avatar
Let me know if any of those dimensions are off. I used a Mitutoyo CD-6"CS Digital Caliper to grab those dimensions right off of a chassis, so test with a scrap piece of wood like 1/4" Medium Density Fiberboard (MDF) before cutting expensive Carbon Fiber with those dimensions. Which, by the way, the 1/4" MDF ends up around .200" thick and actually makes a fairly decent practice chassis in a pinch.
SammyXp is offline
Old 04-07-2004, 08:10 AM
Im doing the same thing for a buddy at work too. And you saved me alot of time! I do it the same way, calipers and the chassis..... But the cool thing about my set up at work is I run a laser on top of the other machines(waterjet,cnc router,cnc mill) and to make sure everything is lining up I just throw in a piece of 1/16th plex and laser it out. It SUPER quick so I'm able to see if its off or on in a matter of a minute or two.
stumper is offline
Old 04-07-2004, 09:51 AM
SammyXp's Avatar
Hey what CAM package are you guys using, Stumper? If you want, I could send you the IGES solid model so it would be easier to program the CNC. In turn, let me know how it fits so I can update the dimensions on the drawing.
SammyXp is offline
Old 04-07-2004, 11:55 AM
Sammy is the Next BMI or Warpspeed Designing his own stuff
Old 04-07-2004, 12:11 PM
SammyXp's Avatar
Haha, not likely. Those guys make some really nice stuff. But I'm lucky enough to have some pretty huge resources at my disposal at my workplace so I don't mind putting it to use to help some fellow RCers out.
SammyXp is offline
Old 04-07-2004, 12:21 PM
I already drew it up using corel. I'll laser out a piece tomorrow and compare it to chassis and let you know. I would have done it today but he forgot his car........But for both the router and mill Im able to use enroute.(scanvec )
stumper is offline
Old 04-07-2004, 01:30 PM
SammyXp's Avatar
Oh ok, EnRoute allows DXF import so you could have used this file instead of spending the time making it in Corel!
File Type: zip
SammyXp is offline
Old 04-07-2004, 01:57 PM
Yep it does allow DXF . But your file is .dwg . I wasnt able to import it.
stumper is offline
Old 04-07-2004, 02:44 PM
SammyXp's Avatar
Sorry. Try this...
File Type: zip
SammyXp is offline
Old 04-07-2004, 03:18 PM
didnt work for me
