Old 04-07-2004, 03:23 PM   #16
SammyXp's Avatar
The DXF / DWG files are a format used to import the actual lines into AutoCAD or any other software that uses that translation method. You should still be able to read the jpg at the top of the page.
SammyXp is offline   Reply With Quote
Old 04-07-2004, 03:49 PM   #17
ok that one worked!
stumper is offline   Reply With Quote
Old 04-07-2004, 03:58 PM   #18
nashrcracer's Avatar
R/C Tech Charter Subscriber
dxf worked like a charm.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 04-07-2004, 03:59 PM   #19
Send a message via AIM to True R/C Racing
guys if your going to make a chassis *Note* make sure switch layout like the WArpspeed
True R/C Racing is offline   Reply With Quote
Old 04-07-2004, 08:53 PM   #20
Why?
Old 04-08-2004, 01:46 AM   #21
lee82gx's Avatar
great work.Got anymore chassis' drawings??I'm looking for the Yok-SD...
BTW,can someone introduce a setup for milling/cutting carbon fibre chassis??
lee82gx is offline   Reply With Quote
Old 04-08-2004, 06:50 AM   #22
SammyXp's Avatar
Switching the layout would definitely suit the Clockwise rotation most ROAR tracks stick to, but if someone has already grown accustomed to the inherent torquesteer on the factory layout, then switching the layout might only confuse them. It's definitely worth a shot if you're looking for something different, though.
Note, in the drawing, the dimensions are exactly as they are on the factory chassis. If you want to move the battery cells inward, you'll have to adjust the dimensions. Other geometry that is not on the drawing is the holes for the front and rear brackets. It might be best to assemble the chassis and drill the holes last, to align them properly with the brackets to avoid a tweak.
If someone wants to send me a spare Yokomo chassis, I can model it up, too.
FS/trade TC3 Rolling chassis w/motor bodies and ESC w/extra chassis and extra's TC3guypgould R/C Items: For Sale/Trade 17 07-08-2007 02:00 PM
circuit designing/drawing software onnetz Chat Lounge 3 04-13-2006 08:33 AM
Blank pictures for drawing DinoXXX Painting, Designs, Graphics and Photography 4 04-15-2005 04:31 PM
My Drawing "Talent"...... MaverickRacing Chat Lounge 6 01-11-2003 01:39 PM
1/12 trinity switchblade rolling chassis for sale/trade for 1/10 touring chassis largabaynus R/C Items: For Sale/Trade 1 03-03-2002 01:58 PM
