Integy Automatic Tire Truer >
Old 04-01-2004, 08:50 AM
RichO's Avatar
Default Integy Automatic Tire Truer
Anyone tried the new Integy Automatic tire truer that they are advertising? I am interested in getting one but have not seen any reviews about it yet.
RichO is offline
Old 04-01-2004, 08:53 AM
RichO's Avatar
It seemed like $189 for an automatic tire truer with a case was a pretty good deal. I believe it has the same motor that their manual $120 unit has.
RichO is offline
Old 04-01-2004, 10:05 AM
I have one, it I functioned without stopping in pre worlds here in Brazil. Perfect I would say
NoFear is offline
Old 04-01-2004, 10:20 AM
RichO's Avatar
Does it have the auto-return feature like the Hudy's do? What I mean is does it do a two cut pass and shut down or do you need to sit there with it?
How big was the power supply you were using? Did it require a lot of passes to cut tires?
Thanks for the reply!!
RichO is offline
Old 04-01-2004, 10:31 AM
Auto-return in fast mode.
Fit 1/12 to 1/8 scale (40-80mm diameters).
High torque motor. Variable speed adjustable.
High precision. Taper cut (0-3 degrees).
Input 12VDC
In Pre Worlds , i used 30 Amps Input RiverGate ,
I more used truer with three chargers , 2 milenium 1 TurboThirty
I no have problems for input
NoFear is offline
Old 04-01-2004, 01:09 PM
lastplace's Avatar
I have the manual unit and like it very much, I added the Hudy carbide bit, cuts great.
lastplace is offline
Old 04-01-2004, 04:19 PM
GoFaster's Avatar
Nice bush in your signature there NoFear. :P
GoFaster is offline
Old 04-01-2004, 05:55 PM
Speedo's Avatar
edit - was looking at the Eagle truer.
Speedo is offline
Old 04-02-2004, 03:34 AM
Liked them small stars?
NoFear is offline
