Electronics Change and problems
Hey Woohoo my first post, anyway I got new Radio gear for my FTTC3 and is there anything you need to do to the camber caster servo esc etc.... Also my car moves from side to side and wiggles all over the road what could vbe the problem?
make sure setup is correct. Camber and Caster Are both the same. On the radio make sure everything is good. the wiggling can be tires
Sounds like uneven steering links. . . .the ones that go to the front hub-carriers, check them to see if their the same length. Loose wheels could also be the problem. Even if you have un-even camber, it shouldn't be a problem.
try Team AE webbie for decent setup example. Get the correct tyre insert combo info from ppl running at your track.
Approach them for help.
