Old 02-16-2010, 10:08 AM   #46
Krio's Avatar
Trader Rating: 150 (99%+)
Originally Posted by csracing View Post
My truck is plenty fast with the RS, but I still have the wierd starting issue.
fwiw my brother is using a hitec hs625mg and I have the bls451 in all my cars.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 02-16-2010, 10:49 AM   #47
Trader Rating: 16 (100%+)
Originally Posted by or8ital View Post
Lots of people run that combo no problems. I would guess this problem is in the distinct minority.
Originally Posted by Krio View Post
It is definitely a hit or miss issue. I've set my younger brother up with an RS and SS17.5 with no issues whatsoever....other than the fact no one believes he has a stock motor in there as he pulls wheelies down the straight if a bump lifts the nose a touch.
I will need support like these...THANK YOU...
Old 02-16-2010, 03:34 PM   #48
jmackani's Avatar
Trader Rating: 14 (100%+)
I am running futaba servos and I still had the cogging issue. I had to advance the timing on the ballistic 13.5 to get it to stop.
jmackani is offline   Reply With Quote
Old 02-16-2010, 03:45 PM   #49
csracing's Avatar
Trader Rating: 22 (100%+)
how much did you have to advance it?
csracing is offline   Reply With Quote
Old 02-16-2010, 04:15 PM   #50
Cedartrack's Avatar
Originally Posted by NovakTwo View Post
I have questions for those of you having difficulties running Novak motors;
What servos are you running?
Have you installed different servos to find that the problem disappears?
Had problems with 203 with 17.5 ss and jr 9100t.
and 203 with 10.5 ballistic and jr9000s.
The 17.5 works ok now with a capacitor on the receiver, no cogging. I gave up on 10.5 and put in a 5.5 in dual mode for mod.
Munn Mafia
SC6, RT6, and a Mini8 ( :
Cedartrack is offline   Reply With Quote
Old 02-16-2010, 05:24 PM   #51
jmackani's Avatar
Just one notch past the N on the can. I tried decreasing the timing on the motor and it made it worse to the point it would cog on the stand without a load on it. I know the feeling to give the car a bump start by pushing it at the starting line.
Old 02-16-2010, 06:06 PM   #52
AdminD's Avatar
Default Novak Sensors angle
Novak Two,
Is Novak SS Sensors at exact same position angle like 120 degree,
equally to all 3 Sensors. ?
Sliders
AdminD is offline   Reply With Quote
Old 02-17-2010, 03:33 AM   #53
Default Ballastic 10.5 and RS 203V
As the motor is factory set too 30 degrees what would the suggestion be for setting the timing on the the Esc. Also suggested rollout for a 1/12th pan car.
tellan is offline   Reply With Quote
Old 02-17-2010, 07:08 AM   #54
Company Representative
Originally Posted by AdminD View Post
Novak Two,
Email [email protected] for assistance with your question.
NovakTwo is offline   Reply With Quote
Old 02-17-2010, 10:53 AM   #55
JayL's Avatar
Does novak even have any timing ramp esc's?
why would their motors be expected to work with one then?
JayL is offline   Reply With Quote
Old 02-17-2010, 11:18 AM   #56
All ROAR approved, Spec motors are built to the same specifications. ESCs featuring timing advance options have to work on these motors as approved.
Old 02-17-2010, 11:29 AM   #57
Absolutely no problems using a Novak 13.5 SS with a Tekin RS on 1S with a LiFe RX pack in a WGT.
My fast laps are almost the same as my 1/12 set-up (about .1 - .3 sec off on average).
AreCee is offline   Reply With Quote
Old 02-17-2010, 12:44 PM   #58
AdminD's Avatar
I'd preferred transparent answer in this thread ?
Sliders
Old 02-17-2010, 12:48 PM   #59
Trader Rating: 38 (100%+)
I think NovakTwo is telling you they aren't the best person to answer it. I am sure everyone would welcome you posting the answer back in this thread.
or8ital is offline   Reply With Quote
Old 02-17-2010, 12:53 PM   #60
AdminD's Avatar
Fine.
Sliders
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Tekin Vegas 2.0 Setup and Support Randy_Pike Electric Off-Road 1713 12-06-2011 05:31 PM
Tekin Rs/Rs pro V200 offroad setups only JdogL Electric Off-Road 272 02-04-2010 11:54 AM
