F-103 suspension position ? >
Old 02-14-2010, 01:15 AM
Questions?? F-103 suspension position ?
hello~
who can tell me whats the difference between this 2 positions ?
if im running with rubber tyre, which position i should use ??
thx~
Attached Thumbnails F-103 suspension position ?-103_level.jpg   F-103 suspension position ?-103_.jpg
pope is offline
Old 02-14-2010, 08:53 AM
fat500's Avatar
Trader Rating: 33 (100%+)
I used to run the lower chassis mount with the adj. shock collar on. If i ran the upper mount then I had to take the shock collar off. Upper mt. with the collar puts too much tension on the rear pod and the chassis will not sit level. the rear pod will be slightly pushed to the ground. lower gives you more fine tuning.
put a soft spring on the rear too. That white is wayyyy too stiff.
fat500 is online now
Old 02-14-2010, 09:26 AM
robk's Avatar
Trader Rating: 22 (100%+)
I always use the bridge type mount for foam tire, it gives more on power steering. Generally the flatter the shock, the more on power steering. You may want to start with the post, and remember that if you want more on power steering, you can use the bridge.
robk is offline
Old 02-15-2010, 03:42 AM
fat500's Avatar
using the upper mount puts more push on the rear pod forcing the rear tires to the ground giving more on power go but may be loose off power. you basically have to play with the car to see what suits your driving style/track. this car is very sensitive to chassis changes so make 1 change at a time.
Old 02-16-2010, 06:18 PM
oh i see...
yesterday i try it with the sus with "post position" with front and rear new RiDE H1(medium) , the rear trackion is very good, but, the car is serious under steering in large corner !?
small corner is ok so far. my front spring is soft so is that mean i have to use
stiff front spring or else ??
pope is offline
Old 02-16-2010, 06:46 PM
robk's Avatar
Originally Posted by pope View Post
oh i see...
try the bridge if your pushing in the sweeper
robk is offline
Old 03-03-2010, 07:37 AM
thanks all !
since im not good at rubber tyre, your advice is real useful !
last week i have took the 1st place o TITC Formular class ~
lucky !
just need to thanks you all ! i love you
pope is offline
Old 03-03-2010, 02:16 PM
robk's Avatar
robk is offline
