Old 02-15-2010, 11:23 PM   #31
anyone near u or that u race with that would let u try their hotwire in your comp??, this would eliminate comp or hotwire if it works or not
onto greener pastures
stuff for sale associated 12r5 $175, team magic 1/10 pit bag $40, top racing pit bag $30, KO helios with spektrum module and 3 receivers $200, CEN CT5 $100 all are plus post
dangles is offline   Reply With Quote
Old 02-16-2010, 12:55 AM   #32
Geezatec's Avatar
Originally Posted by Randy_Pike View Post
If you're having installl issues you should make sure you're running the latest version of the .Net framework.
Also during the install disable any anti virus you have running.
When you install the latest software(hotwire 4.0 right?) do you get both icons on your desktop? 32 bit and 64 bit?
.net framework, I was messing with, on remote cfonnection on my desktop. Window 7 Utimate 64 and Vista Will not DL .net framework, any versions of Framework on Windows 7. Any other ideas??
Geezatec is offline   Reply With Quote
Old 02-16-2010, 02:44 AM   #33
tc3team's Avatar
It's odd how both versions of Windows will not dl .net framework.
I'd be inclined to find a windows tech forum and seek some answers there to sort that first, if it's possible.
(Only looking at it with some logic - which isn't always the answer though! )
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-16-2010, 09:24 AM   #34
Trader Rating: 38 (100%+)
Windows 7 has the .net framework 3.5.1 on the disc. Go to control panel, programs, turn on off windows features. It is enabled by default.
or8ital is offline   Reply With Quote
Old 02-16-2010, 09:43 AM   #35
mpboost's Avatar
Originally Posted by ottoman View Post
I have personally seen two cases were the Hotwire was not seen by the computer because the cable was not inserted into the Hotwire far enough.
+1
I am embarassed to say I had to call Tekin support when I first got my Hotwire 2 weeks ago for help because I simply didn't plug the cable in all the way. I had the same symptoms described so far except I am running on a Win XP netbook. I went through all the troubleshooting steps on the website before finally calling.
As it was explained to me over the phone, the USB cable must be flush or inset when fully inserted (no gap whatsoever between the hotwire case and usb cable). It took a bit more insertion force than most USB connections do to get the connection fully seated. The pins in the USB connector that provide power engage before the pins that transmit and receive data do, and even if you see the LED's on the hotwire and ESC light up it doesn't mean they are communicating.
-Patrick
My Race fleet: TC4, TC5, RC12R5.1, F103R
mpboost is offline   Reply With Quote
Old 02-16-2010, 10:05 AM   #36
Geezatec's Avatar
Originally Posted by mpboost View Post
+1
If you read my post on first page, I discribe it pretty well. If .net framework is on programs of Window 7, it would be listed under programs, which is not. Reading about .net framework, it used with Window 98, NT, to XP. .Net Framework is not supported by Vista or window7. I tried to DL .NET Framework 2.0 SP1. I fet on screen " this product is not supported on Vista Operating System". Reading on Tekins websight, Two Theads on Window7, seems like Tekins had not come out with window 7 upgrade, yet. Even though disabling my anti-virus the same problem.
I'm just useing my laptop with Tekins 4.0. It work well on Windows XP. New Computer (desktop) Windows 7 Ultimate would wait till I return to US, so I could take a better look at it.
Old 02-16-2010, 10:17 AM   #37
You are mistaken. The .net framework would not be listed under programs. It would be listed under "windows features". Its where you turn off things that come standard on Windows like Internet Explorer.
The latest software works fine on Windows 7. Also the version of .net framework you tried to download is not supported b/c it is old. The newest version (not in beta) is 3.5.1 and is included with Windows 7.
Old 02-16-2010, 03:17 PM   #38
Geezatec's Avatar
I'll deal with it when I get back to US. Go back to repteins problem, he started the thread. His problem sounds like the same problem that occurs with mine. He just really say much about it. I put my .10(cents) in.
Old 02-17-2010, 08:45 PM   #39
Send a message via AIM to repstein Send a message via Yahoo to repstein
Well my problem turned out to be I just did not have the usb cabled pressed in far enough. You really have to press that sucker in there. Worked without any problems. It snaps in when you pretty it in really hard. I just figured I saw the lights come on when I put it in. Thanks for all the help because this thread solved it for me.
repstein is offline   Reply With Quote
Old 02-17-2010, 08:56 PM   #40
Geezatec's Avatar
Kewl dude! Mine it work good with XP, Windows 7 it doesn't. I have to wait.
Old 02-18-2010, 08:14 AM   #41
It works fine with Windows 7. I am running Windows 7 64 bit.
Old 05-03-2012, 01:34 AM   #42
Thumbs up
Thank you! You have to hear a click for it to be working properly. With it pushed in 3/4 of the way the lights turn on but no real connection.
archiller is offline   Reply With Quote
Old 10-26-2012, 08:20 AM   #43
Bit of a thread dig but im having the an issue, Downloaded hotwire , once done and opened it comes up with the little box saying how to connect then stays like that. If i click update it says that it is un able to do it at this time try again later. what do i do with it to make it work?
Carpet: Tamiya M05V2 R
Asphalt : Tamiya M07 , Xray T4'17
d.k.vmatt is offline   Reply With Quote
Old 10-26-2012, 09:57 AM   #44
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Matt check your version:
Plug in ONLY the Hotwire and launch the software, hit the "help" button and read the version. Latest is 8.4.1
What is shown?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-26-2012, 10:05 AM   #45
Yep it says 8.4.1.
How do i get the actual hotwire program to launch so i can put my car in blinky mode?
