are parma tires direct fit in a t-fource? coz the crc ones have this deep hole in the middle for the nut.
Originally posted by crimson eagle OD, Crashby, Bill, JRRC etc, I think Bill's original idea will work best to get everyone out to begin with. By that I mean we start out with stock for a few weeks and then see if everyone is liking that we could stick with it or if there is enough interest to go to 19T without killing the stock class then go from there. I think Crashby siad - it's what everyone has- so there will be less equipment issues. What do you think? Chris. Got some bits and pieces to bandaid together a 12L3 (yes, I know i'm cheap:lol: ) Just need some more stuff before I can start assembly. Who makes the stick on teflon disks for the upper pod plate? Does anyone use them anymore, or do they sand it smooth, use grease, or the teflon disks from the F103? Sorry for all the newbie questions on something that's probably been covered 10 times before, but it's been at least 5 years since i've run a non-tube car :lol: -James |
Stick on teflon damper disks? Wasn't that Dan's R/C Products? I remember they had the bananna yellow header card.
Originally posted by dakrat are parma tires direct fit in a t-fource? coz the crc ones have this deep hole in the middle for the nut. Parma fronts use flanged bearings, so the CRC kit bearings will not work. |
Originally posted by JamesArluck Sounds like a good idea Chris, although I think you'll find out pretty quickly that most asphalt tracks are too wide open for 4 cell 12th scale stock. Hopefully, after a race or two, everyone will be wanting a little more horsepower. As we discovered last summer-19t asphalt is fun!:nod: |
Originally posted by revzalot Yeah it's time to do the OD shuffle. |
My imitation of OD
(not the best work in town, but i like it) Here is how it was wired before i tore it apart http://img.photobucket.com/albums/v16/mbxb4/oldwire.jpg And here is how its wired now http://img.photobucket.com/albums/v16/mbxb4/newwire.jpg |
Originally posted by crimson eagle OD, Crashby, Bill, JRRC etc, I think Bill's original idea will work best to get everyone out to begin with. By that I mean we start out with stock for a few weeks and then see if everyone is liking that we could stick with it or if there is enough interest to go to 19T without killing the stock class then go from there. I think Crashby siad - it's what everyone has- so there will be less equipment issues. What do you think? Chris. I wouldn't care if I came in last (somewhat likely). Just getting to race with you guys is a joy. |
Looks good Primus. The surgery was a success.
James has a good point about outdoor tracks being much wider and bigger. If that's the case, I think 19t would be the hot ticket for asphalt. |
Originally posted by revzalot Looks good Primus. The surgery was a success. James has a good point about outdoor tracks being much wider and bigger. If that's the case, I think 19t would be the hot ticket for asphalt. 19T would be a great blend of speed and sanity. |
inside outside
The carpet tracks that we race on in Nor-Cal are pretty big (does anybody know the dimensions at Stockton?). As a matter of fact, I think the tracks we ran 19t on last year at Santa Rosa and Cloverdale were somewhat smaller than Stockton. Differences in bite and track design notwithstanding, stock racing should be about the same, indoors or out.
Originally posted by primusblowsgoat My imitation of OD Nice job, primus! I have discovered that when your car looks that good it is MUCH FASTER!!!!!:nod: |
Re: inside outside
Originally posted by odpurple The carpet tracks that we race on in Nor-Cal are pretty big (does anybody know the dimensions at Stockton?). As a matter of fact, I think the tracks we ran 19t on last year at Santa Rosa and Cloverdale were somewhat smaller than Stockton. Differences in bite and track design notwithstanding, stock racing should be about the same, indoors or out. For most track setups, Stockton's back straight is 120' long (outside to outside) and would likely be called 100' long (inside to inside). |
Well, I had my 12L4 out on the track for the 1st time tonight. It is alot different than my TC. 50 x 100 carpet track. I will race it this weekend. I hope my batteries will last. My new 4 cell packs will not be in till Tuesday next week.
The seems to have to much steering. I started with the kit setup. I changed the center spring to a silver 8.0 from the green 6.0 and it seemed to help some witht the steering. Tires where purple fronts and grey rears. Overall I think it is going to be fun. We had a indoor asphalt track open a month ago 55 x 100 in Frederick, MD. It is really smooth. We are planing on getting 12th scale going this spring. |
Originally posted by SRW141 The seems to have to much steering. I started with the kit setup. I changed the center spring to a silver 8.0 from the green 6.0 and it seemed to help some witht the steering. Tires where purple fronts and grey rears. |
| All times are GMT -7. It is currently 02:56 AM. |
