-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
truggy100 08-31-2016 11:34 AM
have the much more fleta 1s blinky mode ????
Schwarta 08-31-2016 06:02 PM
Managed to get an ofna manual lathe (20002), will it be ok to use a 4s lipo?
TOADYY 08-31-2016 06:04 PM
New 1/12 Protoform body
http://racepf.com/index.php?p=catalo...rch_str=BMR-12
chad508 08-31-2016 06:37 PM
4s will be fine. I use a 2s and have no problems. Just cuts slower.
Antimullet 08-31-2016 09:00 PM
Anyone try the xenon Opt-0081 option for Xenon front ends that convert it to a damper style front end?
If so what was your oil weight used and how did the damper frontend help/hurt your lap times?
Thanks!
Aaron
chad508 08-31-2016 09:20 PM
Thanks!
Aaron
I installed mine today and plan to run sunday. I started with 10k but feel I'll end up go to 30k.
MontanaMaxx 09-01-2016 01:16 AM
Originally Posted by Racermac73 (Post 14655126)
SMC is awfully hard to beat for the money
And best customer service i had in a long time
aracefan 09-06-2016 03:14 PM
Just wanted to post my latest body. . .
Only the 2nd body I've painted in the last ~16 years. Some of the tape lines aren't quite straight and not even to both sides - but pretty happy with it. Need to take my time, I tend to rush once I start.
Tried to do a Gulf Racing theme.
https://im1.shutterfly.com/media/47a...D720/ry%3D480/
aracefan 09-06-2016 03:17 PM
Originally Posted by TOADYY (Post 14655805)
This will be my next body. Thanks for posting!!
http://racepf.com/images/products/secondary/1125.jpg
Gonna try and do either the Audi paint scheme, or maybe the Toyota. . . :tire:
DesertRat 09-06-2016 04:38 PM
I love how in the press release picture of their new body Protoform decided to use an Ulti front rim and a BSR rear. :D
Your home paint job is better than any I have attempted, I mostly do easy fades and solid colors. I did paint a car prune juice maroon by accident once, though.
Rabbit0317 09-07-2016 05:26 PM
I'm wondering what's a good starting spur gear for running 13.5t?
303slowdown 09-07-2016 05:48 PM
I run a 78 for 13.5
Rabbit0317 09-07-2016 07:52 PM
Originally Posted by 303slowdown (Post 14663594)
I run a 78 for 13.5
Okay thanks!
71schaeffer 09-12-2016 07:42 PM
Originally Posted by Antimullet (Post 14626936)
Just an FYI, depending on motor turn you can run a HW XR-10 justock without a voltage booster up to (tested) 6.5t. I run these in 17.5 blinky primarily. Even though they are listed as a 2s ESC, just like the original justocks, they work fine in 1s.
I notice no degradation in servo speed. If you are going full mod 3.5t you may need a booster.
Anyways, my point is these are lighter and more compact than a V3.1 and just about anything out there.
So do you need a reciever battery? I am new to 12th scale and im trying to learn what esc's i can run without a booster on 17.5 that say 2s and so on. I am use to offroad 10th so going to onroad is a bit fustrating to learn lol
Antimullet 09-12-2016 11:07 PM
No even though it says a 2s it works perfect on 1s with no booster and no receiver pack. My servo has no noticeable slowness to it at all.
Been running them a long time now with no issue.
