-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
LloydLoar 01-23-2015 12:14 PM
Originally Posted by DesertRat (Post 13800168)
Their website still lists that 1/12 scale tub chassis that I think was tested and determined to be no good years ago. I still think it looks cool.
Other than all of those super-fast euros, though, right? Other than those guys and Dumper (who are the only ones using it), yeah, it is no good. lol.
DesertRat 01-23-2015 12:37 PM
So the molded tub chassis revolution should start any day now? :confused:
LloydLoar 01-23-2015 12:50 PM
It is hard to get and it costs a lot of money - so very few people have the practical hands-on experience with it that would drive increased sales and popularity. Not sure why this is surprising or confusing.
patorz31 01-23-2015 01:15 PM
Damned expensive, last one I saw was 15,000 yen when i was in Japan, a year or so ago. Looked really cool though.
----- 01-24-2015 02:07 AM
it ususally goes for 160-170€ ...
I´ve been running the Black Art chassis for almost 3 years now and never had to raplace a chassis due to warpage (or any other reason). Even hard hits don´t require you to rebuild the car. Based on my personal experience I´d say this is one of the best investments you can make for your CRC car.
chris moore 01-24-2015 09:17 AM
170 euros translates to just over 190 US, tough to justify spending that much on one part when you can buy a new kit for just 9 dollars more.
oreo 01-24-2015 12:36 PM
.....Monkey Breaker chassis(t-bar car).Anyone remember ......?:nod::tire:
DBM 01-24-2015 12:41 PM
1 Attachment(s)
Made some more progress on my old genX. The battery relocation brackets fit nicely and the new shock mount and beefed up upper pod plate fit well. Installed the long arm setup on the front yesterday, and finished up the esc wiring this afternoon. Unfortunately the output shaft on my little servo is much smaller than I expected, so my servo saver does not fit. I'll either have to order a new servo or a tiny servo saver in order to get this old car on the track. The only servo available locally that will fit is a hitec 225mg which will get it on the track for Wednesday practice, but I've been reading that it isn't a very good servo. Granted, Mt car is old and so are all of the electronics, so it fits the theme...haha
CFR 01-24-2015 07:27 PM
Anyone using the Blitz T128 bodyshell? Your thoughts please.
http://www.team-titan.com.tw/product...php?code=60908
blwaz23 01-24-2015 09:30 PM
Can someone explain to me what roll out is? thanks
SLOWINSLOWOUT 01-25-2015 12:05 AM
Its the distance your car will move with one revolution of the motor.
(tire diam.*3.14)
------------------- =roll out
(spur/pinion)
avink007 01-25-2015 05:05 AM
Originally Posted by lpittman (Post 13799909)
Will you reply back with your results? I am quite curious about this as well.
Also about the weight it adds to that servo. If anyone can measure that it would be great!
It adds 1.1 grams of weight to the servo and only 2 screws to secure it to the chassis. Team Associated 12R5 servo mounts weigh 1.0 gram but use 4-6 screws to mount the servo to the chassis.
avink007 01-25-2015 05:14 AM
Originally Posted by InspGadgt (Post 13799892)
That's pretty cool...I'll have to see if that lines up well with the X-ray chassis holes. Will go nice with the rest of the orange in the car :)
If the Xray chassis holes are drilled for the 9650/3650/951 it would work. The holes are about 42.8mm apart (tried to get close with a caliper). The widest part is 48.3mm (material past screw holes). Hope this helps.
CFR 01-25-2015 03:24 PM
HTH by the UK's LMP12 section chairman
http://www.brca.org/sites/www.brca.o...%20Ratiosx.pdf
More technical articles here
http://www.brca.org/sections/subsect...-articles/1144
Car Breaker 01-25-2015 05:09 PM
I use it on asphalt. Feels like combination of amr12 and tr12.
