thanks for the reply, a racer who knows a lot more then me about rear drive and ball diffs told me more then likely my diff was not built right, but in the rush of a race day we didnt get the chance to pull it apart so i think it is the diff, i know the last outing before a rebuid it went dead straight under power, but thank you anyway i will check my tweak, but once again if anyone has any diff building tips please feel free to share them.
cheers oldenuff |
Sometimes the answer is just as simple as it's not tight enough?
Originally Posted by oldenuff
(Post 13429126)
cheers oldenuff Here is CRC's method. Aaand finally, IRS's tech tips has several tips related to diff building. Hope this helps! |
Falling in love with driving my recently accuired 12th scale.
Questions: 14 gauge wire okay for 4.0 motor? My purchase came with many tires, but pink rear and black fronts are the recommended tires for my track. Would truing and using grey/magenta/pink rears be beneficial to practice or would those compounds throw off the feel of the car. I dont see myself traveling to other tracks, so this quiver of tires is just taking up space. Basically, should I just donate them or practice with the extras? |
Do you guys think 16ga wire is big enough for 1s/17.5?
Originally Posted by tommy911t
(Post 13429463)
Originally Posted by CanyonCarverR1
(Post 13429529)
Thanks you, Tech Champion.
I'm going to interpret that as as "Yes, donate when possible and practice when you can." The 12th scale mysteries continue to unravel... |
(Post 13428917)
hi guys, just searching for some advice, Between ball diff rebuilds ( which i am new too ) i am noticing sometimes i get it right and sometimes not, but i don't know the difference of what i am doing from 1 build to the next:confused:,. sometimes the car pulls one way under power generally left and sometimes it tracks straight, any hints as to what i should be doing during a rebuild or what i should be looking for or even where i am going wrong, any advice would be greatly appreciated.
cheers oldenuff |
http://www.youtube.com/watch?v=U4999JNihYI
http://www.youtube.com/watch?v=NWfKyj3t5tg A look into Masami Hirosaka's rc life. |
That video with Masami is amazing and pure rc...
At 44 min in the second video, the Tekin tech simply says, "too much power." I wish I spoke thier language or even knew the context, but the Tekin tech's facial expression is priceless. |
hi guys, thankyou for the responses, this gives me something to work with.
cheers oldenuff:D |
Originally Posted by InspGadgt
(Post 13429702)
A commonly overlooked cause to this is the left side hub being on too tight. You need to have a slight bit of play in the rear axle otherwise the rear bearings bind. Since both rear bearings are on the left side of the diff...it will cause the car to pull left.
(Post 13428917)
cheers oldenuff http://m.youtube.com/watch?v=-ct2L3KEkE0 |
Guys looking for Xray X12, NOT 2014 spec.
If someone have for sale - please pm! Roller only is preferred. |
Originally Posted by I)arkness
(Post 13431421)
ive heard of people using o-rings as spacers and a cushion for the axle? is this worth trying or not to bother. just stick with the little bit of play
| All times are GMT -7. It is currently 10:55 PM. |
