-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
jimiw8 03-16-2014 05:59 PM
CRC XTI Roller
4 Attachment(s)
Sellling my new CRC XTI roller. Just built with CRC up grade kit. Never Ran.
Very nice car, with all the little trick goodies.
$ 180.00 shipped to 48 U.S.
Roller with Futaba 9650 steering servo
2 sets of CRC Pro cuts, back fronts, yellow rears
CRC XL chassis, Less front and rear end, Excellent Cond
Protoform AMR body, will need rear wheel wells opened up. great condition
Extra parts left over from up grade.
andrewdoherty 03-16-2014 06:12 PM
Originally Posted by B00t13g (Post 13102426)
Probably a dumb question. Any idea what size diff balls the rw spur gears take? I assume it's 1/8.
Yes, 1/8"
John birmele 03-16-2014 06:48 PM
i run the X-ray x12 2014 and i have run up to a 105mm rollout with no issue using a 72 or 73 tooth spur!
xrayracer1 03-17-2014 01:32 AM
Originally Posted by Radio Active (Post 13100756)
What I forgot to mention is tyres. I'm using Ulti Hard front, and Ulti Soft rear. Speedmind 30R and 32F works well too and lasts a bit longer.
Thanks for the help.
bama racer 03-17-2014 07:57 PM
What the pros and cons of a inline set up vs a transverse set up?
JamesL_71 03-18-2014 05:58 AM
Originally Posted by SpeedSecrets (Post 13102164)
I'm currently running the S120LTX 17.5 blinky and find it difficult to find small enough spur since the motor plate has very little room for adjustment. While I really like the car, be prepared to figure out the gearing option if you will be running 17.5 blinky or others that require 100+mm rollout.
Anyone know where I can find 70T or 71T 64P pan car spur gears? PRS makes a 71T but I can't find it available anywhere.
Xenon makes a 70t spur gear... I believe it takes the smaller 3/32" balls, though.
You can order direct from their website, but the 70t isn't listed for some reason. Maybe email them?
RedBullFiXX 03-18-2014 07:17 AM
1/8 balls in all Xenon gears, Teru said he is working on a 68T 64p gear as well
RedBullFiXX 03-18-2014 07:21 AM
That's not something that can be categorically stated
Different track, cars, and driver preference will decide
Inline should be more stable, Transverse can have more rear weight bias, and possibly be on the aggressive side, but as Martin Crisp says, sometimes the opposite is true :D
Andrew S 03-18-2014 11:56 AM
When I went from inline to traverse in my xray, I expected it might get more aggressive, but rear became more planted and it just felt nicer to drive.
My laps times improved a lot after making that change!
DesertRat 03-18-2014 12:30 PM
This may be anecdotal evidence but the most mellow 1/12 car I have ever driven is my CRC Gen-XL with the battery transverse in the rearmost position. For a while (when my local HS was still in business...) this was my lend-a-ride for people who had never driven a 1/12 car before, but this was on medium-low traction and not tacky grip.
However, both my transverse Xti and my transverse XL suffered massively on grip. When I ran my super-mellow transverse car at the 2012 IIC, the handling was great and the only thing holding them back was me. At the 2013 IIC they were both GARBAGE on that tacky rug. I still haven't figured out why but this year I will have a rolling, ready-to-race inline car in my bag just in case.
Andrew S 03-18-2014 01:45 PM
3 Attachment(s)
I just changed from the orion R10 esc to the hobbywing V3.1 to save some chassis space.
Eliminated the external caps and the external switch.
Also changed the wiring to 14g batt and 16g motor wires with motor tabs extensions.
No more wiring tweaking!
The hobbywing delivers a much smoother power than the orion. Liking it so far!
jsinclair 03-18-2014 02:54 PM
I'm assuming you tin the entire length of the larger gauge wire that you're using as a joint.?
Andrew S 03-18-2014 03:05 PM
no, they are not wires. Check this link:http://www.ultimaterc.com/forums/sho...d.php?t=132258
They are KO propo motor tabs
JamesL_71 03-18-2014 04:11 PM
Teru has been hanging out in the US too long :p
Radio Active 03-24-2014 07:03 PM
I didn't want to look as far back as page 3 for this thread next time, so I'm posting.
Has anyone had any experience with the latest spec Xray car on asphalt? If so, how does it compare to others?
