-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
JamesL_71 07-22-2013 10:33 AM
The only tires I have seen that could potentially be considered "too small" for asphalt 12th are the Gravitys. I believe they are roughly 43.5mm front, 44.5mm rear out of the box. Even so, that is a pretty good diameter for asphalt racing... unless we are talking about a parking lot track.
danthrc 07-22-2013 12:16 PM
Thanks James, this is exactly what I was looking for.
Originally Posted by JamesL_71 (Post 12364934)
Dan,
The current 12th scale classes run in the US at ROAR events(Carpet Nats), IIC, Birds, etc are as follows:
1) Stock - 17.5 non-timing
2) Superstock - 13.5 non-timing
3) Mod - open motor, open speedo
If you are looking for info on what 12th class to run at CT's new track, I highly recommend staying with Stock/17.5. That is what the rest of state(Austin/Dallas) is running... and while 17.5 might have seemed slow at M&M or HT in Austin on the asphalt, Stock 12th is really a pretty dang fun class on a 90x40' rug. 13.5 will be too fast for the newbies just getting into the class...
Josh Keller 07-24-2013 05:42 PM
chevtech23 07-27-2013 08:57 AM
The Futaba BLS 651 servo appears to be discontinued, does anybody know what model replaced it?
LonnyJ1950 07-27-2013 10:01 AM
The BLS153 is essentially the same servo with a standard case. Both are still on Futaba's web site.
http://www.futaba-rc.com/servos/brushless.html
chevtech23 07-27-2013 10:09 AM
ok thanks, i saw "air" in the title and didnt look at the specs, assuming it was air only application
OlGrumpy 07-27-2013 10:21 AM
Pretty new to 12th scale and glad I found this. Read thru some and very informative.
I just picked up a Hyperdrive chassis for running GT class. What servo do ay of you suggest?
DesertRat 07-27-2013 01:51 PM
Originally Posted by Josh Keller (Post 12379969)
Just thought I would share this...http://www.smc-racing.net/index.php?...tegory&path=68
Killer prices too.
I guess I won't need my tire lathe...
Anyone looking for a new Ofna Manual Tire Lathe, Ofna 1/12 Tire Arbor, and Mobgums Tire Arbor Support/Spacer?
Believe me, you'll still need the lathe.
Clegg 07-27-2013 02:07 PM
Yep, what he said. I run these tires and you do still need to true down the rears and round the corners on the fronts if you want to be at all competitive. They come squared up. The fronts at 42mm are slightly big for competitive driving, but the rears are 45mm I think? Way too big.
You just don't have as much foam on the table after you true them as you did before :)
howardcano 07-27-2013 02:26 PM
Joe, what is your opinion on the rims? Do they run true? Are the strong, fragile, or brittle?
Clegg 07-27-2013 02:57 PM
They are just gray versions of jacks white rims. Strong but flexible so they flex on a hit and don't shatter like crc rims. They run as true as any other 1/12 rim or jack wheel... Not perfect on every rim but close enough to be considered good.
OlGrumpy 07-27-2013 03:03 PM
Ok, looks like I may be stepping on toes here, and if I am I am sorry. Just wondering if anyone can help me with what servo is the best for racing these 12th scales, please?
EricF 07-27-2013 03:18 PM
I like futuba S9650 and JR Z3650 those two brands have worked well for me for many years. I yhink some guys as of late have been using (poo, I just blanked the brand) savox or something...
And I see by your "stepping on toes" comment that you are grumpy :-)
E
JamesL_71 07-27-2013 04:57 PM
The new BSR/CRC nylon wheels solve this problem... they are a bit more flexible than the old wheels and can take a much harder hit without cracking.
TonyD. 07-27-2013 05:03 PM
could i race the tamiya RM-01 with other 1/12th scale cars like crc,ae?
