-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Turbonium 10-25-2006 08:44 PM
my car has a set of the alloy mounts from a T4 truck, mounts nice and rigid, after the holes are drilled and countersunk.
wallyedmonds 10-25-2006 08:55 PM
Originally Posted by protc3
green springs will generate alot of rpm but with the voltage in todays cells,they genrate too much heat.i went away from them after the 36 and 3700 cells and went to reds to eliminate power loss generated from arcing and the heat created from this.
never thot of that thx i will try reds
wallyedmonds 10-25-2006 08:57 PM
Originally Posted by Blue Screw
can anyone tell me who makes the servo mounts that will allow me to mount the servo flat on the chassis...
why do some do this just want to know what it realy dos. :D
shaggster 10-25-2006 11:46 PM
Trinity makes them also, and you can use Xray servo posts.
The latest Futaba servo case is molded so you can mount it flat
without posts or mounts. Just a screw and a nut!!!( :lol: )
protc3 10-26-2006 03:15 AM
some like to use bump toe and it also changes the steering geometry a little.it does have a different fell than the angled mounts.
itchy b 10-26-2006 04:13 AM
1 Attachment(s)
this is the track we race on :)
had 17 12ths running last sunday :)
the drivers stand is to the left side of the pic and we run counter clockwise
cannon 10-26-2006 04:15 AM
Yeah, 17 drivers and some didn't turn up ..... who was that itchy :flaming:
dr_hfuhuhurr 10-26-2006 05:51 AM
Actually order a set of TC4 servo mounts. They run really flat to the chassis. You just have to slice off the positioning nub. They look pretty good on the car.
http://www2.gpmd.com/image/a/ascc1111.jpg
itchy b 10-26-2006 06:08 AM
yeah, i hear ya :blush:
something came up at the last minute and i couldnt make it :(
would have been a great day though
Kwikvdub 10-26-2006 07:48 AM
Kwikvdub 10-26-2006 07:50 AM
RPM makes a set that I use on my CRC. :nod:
streetracer745 10-26-2006 08:14 AM
is the 1/12th scale cars as fast and tunable as a 1/10th scale tc? if its just as fast and handles as good, then i might get into it, because there is a leage around here.
RaceAce701 10-26-2006 08:16 AM
in stock iv noticed that the 1/12 lack a tinny but of srtaightaway speed but the cut the corners like they are on rails
streetracer745 10-26-2006 08:19 AM
i wouldnt run stock. i have problems with brushed motors lately, and try to stick to brushless racing ones. would the AE RC12L4 with a mamba or neo be as fast as my yok with the neo-one 4*? and would it be able to take turns faster?
RichChang 10-26-2006 08:27 AM
On an indoor carpet track, as long as my stock 1/12th is doing the same lap times as the fast stock TC folks, then I am happy. So, yes, it is possible to get your 1/12th as fast as a TC.
It is tunable, but simpler than a TC.
-Rich
