Monti-how cool-thats a sweet looking car. btw-the Gate will be moving to Saturday practices come August to prepare for Vegas.
I know its far off-but thought I'd give ya the heads-up. |
Originally Posted by theisgroup
nah, we are just letting you guys win. something about respectig your elders. lol
P2 |
what is the best way to take 3800s out of a crc 3.2. I put two shims under the front ball cup to make a little room. Is there a better way? I also took out the front battery brace, is this needed.
On my Rev.4, I take a pair of pliers and pop the ball cup off the ball stud near the antenna, and flop the shock over the rear pod. Full access to the batteries. All other Rev.4 drivers I know do the same.
http://www.markpayneblog.blogspot.com/ http://photos1.blogger.com/blogger/1...0/IMG_2638.jpg Popping the ball cup off repeadily will eventually ruin the cup and you will be replacing them. The xray end links are awesome, 3mm wrench and they are off in seconds, no slop and last a long time. |
And yes, Mark Payne's suggestion re: the Xray ball ends on the shock is the HOT ticket for trouble-free battery changes. Scottrik |
Originally Posted by Anthony.L
You obviously haven't read the 1/12 setup bible... :p
http://www.markpayneblog.blogspot.com/ http://photos1.blogger.com/blogger/1...0/IMG_2638.jpg Popping the ball cup off repeadily will eventually ruin the cup and you will be replacing them. The xray end links are awesome, 3mm wrench and they are off in seconds, no slop and last a long time. I'm not knocking your 'bible', however, it makes it much easier to relate with people with the same basic build. |
Originally Posted by timmay70
Same set-up for the past 2.5 years. I did put an o-ring on the stud to remove the play in the cup. I like having the same set-up as the team drivers so that when discussing set-ups I can directly relate how my car is set-up with theirs. The stock cup set-up is lighter (especially with an aluminum ball stud - blue is so pretty), and the ball cups are easy to replace. I also hate wearing out the antenna mount, as I glue in the antenna. So in the end, buying a pack of 16 ballcups from AE is pretty cheap insurance.
I'm not knocking your 'bible', however, it makes it much easier to relate with people with the same basic build. Yeah, it probably weighs a gram or two more...then again when we see YOUR name at the top of a national championship list (Mark IS a UK national champ) I'll do it your way. And wearing out the antenna mount? How tightly do you screw things in? I'd bet my antenna mount will last as long as yours does. Finally, this may be the hot ticket for those of you who are "discussing set-ups with the team drivers", those of us here in the real world are finding our own set-ups and continuing to fine-tune those. Of course, the maybe two or three drivers on this list who could demonstrate a measurable lap time difference with EITHER set-up in a blind test between the two... You go get 'em, Scottrik |
I never have had a ball cup pop off in a race or otherwise.. Same set-up for the past 2.5 years. I did put an o-ring on the stud to remove the play in the cup. I like having the same set-up as the team drivers so that when discussing set-ups I can directly relate how my car is set-up with theirs. The stock cup set-up is lighter (especially with an aluminum ball stud - blue is so pretty), and the ball cups are easy to replace. I also hate wearing out the antenna mount, as I glue in the antenna. So in the end, buying a pack of 16 ballcups from AE is pretty cheap insurance.
E |
Originally Posted by EricF
Use some caution when adding shims to shock mounts etc. as it will have an affect on the cars handeling. I beleive that adding shims at the mount raising the shock will give you more on power steering.
E FWIW I agree with Timmay, I still use the standard set up. After many seasons of popping the shock end off and on there is no play in any of the ball cups on my cars. One thing to note is that AE ball cups have a lot of play in them when brand new, and not "distorted", thats why I use RPM ball cups. I have seen pros cars with o rings on the ball studs, BTW. I don't think there is anything wrong with Mark Payne's set up, it looks like a fine way to do the job; for me the old way is easier and quicker. |
First, my post was not meant as a flame, just a suggestion. The fact that you took offense to it is... nm. I thought you were using a link end... at work I have all pictures turned off due to the 'net police. So, sorry for not noticing the implemented set-up. It does look pretty trick.
Originally Posted by Scottrik
Uh, yeah. Just how many of the "team drivers" are using o-rings to take up the slack in their distorted ball cups? You have deviated further from their set-ups than fitting an alternate (and slop-free) removable ball end assembly.
As mentioned in Ericf's post, shims under the ball stud is a setting that we like to play with. Math is not my strong suit, and I don't want to have to try to figure out what proper shim I would need to use.
I hope we get to meet someday. You seem like an interesting person. |
whoa timmay, don't take offense. I was simply posting the lazy man way (aka my way). :p
who makes the "olive" VCS shock spring? :confused:
| All times are GMT -7. It is currently 03:59 AM. |
