DUALSKY XC800TF Brushless Racing Speed Controller >
Old 02-09-2010, 03:50 AM
Default DUALSKY XC800TF Super Small Brushless Racing Speed Controller
Hi, all
DUALSKY has released a new brushless speed controller: XC800TF. This is a full metal shell sensored/sensorless brushless ESC with super samll body size. Advanced passive cooling design, high power and functions.
Specifications:
Dimensions (L x W x H): 34.5x33x18.5mm
Weight: approx 45g (without wires and capacitor)
Instantaneous Current: 800A (FET rated)
Continuous Current: 120A
Resistance: 0.0003 OHM
Input Voltage: 4.8~8.4V (2S LiPo, 4~6 cell NiMH)
B.E.C: 6V.2A
Suitable Motors: 3.5T and higher, sensored and sensorless brushless
Protection: Temp cut, Low battery voltage cut (adjustable)
Mode: Forward with brake (brush/brushless), Forward/Brake/Reverse (brushless)
Adjustment: DDRP profile (Throttle Profiles, Start Mode, Timing Advance), Auto Cell, Neutral Brake, Brake force, Reverse Force, Initial Brake, Neutral Range, Over Heat
Capacitor: Super low resistance capacitor included
Extra features:
Full metal shell
ICE Core technology – Needn’t fan when running 4.5T brushless motor (environment temp 35℃)
DDRP (DUALSKY Digital Racing Profile) - Optimized Punch, Timing and Throttle Curve for different racing environment
Dynamic Digital Timing technology – Auto timing adjust for different motor RPM
Updateable firmware
Super small size
External fan connector
One key to set function
USB link for firmware upgrade and detail parameter set
Setting Information
DDRP
Profile 1: For low grip track or buggy
Profile 2: For 3.5 ~ 6.5T brushless motor
Profile 3: For 4000KV brushless motor
Profile 4: For ≥10.5T brushless motor
Custom: Use USB link to set Throttle Profiles, Start Mode, Timing Advance in PC
Auto Cell (Low battery voltage cut)
1. None
2. LiPo
3. NiMH
4. LiFE
5. Custom: Use USB link to set voltage cut in PC
Neutral Brake
1. None: for buggy
2. 10%: For 3.5~8.5T brushless motor
3. 15%: For ≥10.5T brushless motor
4. 20%: For shaft car
5. Custom: Use USB link to set in PC, the range is 0%~100%
Brake force
1. 25%
2. 50%
3. 75%
4. 100%
5. Custom: Use USB link to set in PC, total 8 values (12.5% 25% 37.5% 50% 62.5% 75% 87.5% 100%)
Must use USB link to set below functions:
Reverse Force
Initial Brake
Neutral Range,
Over Heat
Attached Thumbnails DUALSKY XC800TF Brushless Racing Speed Controller-1.jpg   DUALSKY XC800TF Brushless Racing Speed Controller-2.jpg   DUALSKY XC800TF Brushless Racing Speed Controller-3.jpg   DUALSKY XC800TF Brushless Racing Speed Controller-5.jpg   DUALSKY XC800TF Brushless Racing Speed Controller-7.jpg
srw_g is offline
Old 02-09-2010, 06:12 AM
Tpg racer's Avatar
Looks like a Futaba ESC... isnt it?
Tpg racer is offline
Old 02-09-2010, 07:51 AM
dietDrThunder's Avatar
DO NOT GO TO THE WEBSITE IN THE OP.
It is infested with all sorts or Interwebs nastiness...stay away.
dietDrThunder is offline
Old 02-09-2010, 08:09 AM
mac853's Avatar
Thumbs down
What?
This is terrible.
But i believe it's not only just few of them, what i know so many China sites are contamined by their countryman.
The nation which has more hackers in the world is there.
mac853 is offline
Old 06-08-2010, 01:22 PM
Dan415ms's Avatar
I have one of these, one word. Fanbloomintastic!!
I love it.
Dan415ms is offline
Old 06-08-2010, 03:29 PM
I have a bunch of their airplane speedo's ,and brushless motors.
They are big and bulky.But reliable.I have some of their lipo batts. for r-planes too.So far they are really good batts.
I am impreesed with the small size of this new speedo.
Does it need a fan? or a heatsink? how much?
tc3jp is offline
Old 06-09-2010, 01:05 PM
Dan415ms's Avatar
It says in the manual that it needs a fan below 4.5 turn motors - the case IS the heatsink as it's an all metal design which is a nice feature. I ran it with a 5.5 turn with no issues and it felt cool.
The price in the UK will be around £199rrp I believe.
Dan
Dan415ms is offline
Old 06-09-2010, 01:11 PM
RC MARKET's Avatar
not have Tubro mode ?
RC MARKET is offline
Old 06-09-2010, 01:19 PM
Dan415ms's Avatar
I have only used it in modified where it was amazing but there is a stock profile which uses dynamic timing (like turbo).
Dualsky are also working on a firmware upgrade to equal the Hobbywing/Tekin etc, this is not yet finished as the ESC is brand new but will be very shortly.
Dan415ms is offline
Old 06-10-2010, 01:54 AM
crabboy's Avatar
Trader Rating: 58 (98%+)
I ran one off these speedys and the Dual Sky Motors for a while in mod, it has a VERY small footprint for a brushless speedy, had plenty of power and great low speed control, BUT i ran it on some 35C deg days and just on the 5 min mark it would thermal, i didnt have the USB link so i was unable to disable the overheat feature, also i wasnt running a fan and that would have helped ,but overall a great speedy.
Rhys
crabboy is offline
Old 09-22-2010, 07:14 AM
DaveG28's Avatar
Trader Rating: 65 (100%+)
Is reverse disabled as a default on these?
DaveG28 is offline
Old 03-20-2011, 06:29 AM
kschu's Avatar
Trader Rating: 16 (100%+)
any review on this esc???
kschu is offline
Old 03-20-2011, 07:28 AM
smilekt's Avatar
here are some review .... but i dnt know what they wrote
http://kkchung.pixnet.net/blog/post/28212219
smilekt is offline
