Red 009 Convertion >
Red 009 Convertion
Red 009 Convertion
Old 02-09-2010, 01:01 PM
  #16
I had all the early Xrays. I did a slim version with 3 cells under the belt and the 3 up front by the belt.
With this chassis the battery is under the belt too.
I'm not sure about the 007. I think the 008 is the same. I would need to see the car. Or the chassis at least. Does the 007 use the same gear boxes as the 009?
ads0021 is offline
Old 02-09-2010, 01:03 PM
  #17
Originally Posted by ShagNastyEk9 View Post
there is a big difference between the xray style and his. His has the belt running completely above the top plate, this will allow the electronics to be moved in closer to centerline of the car, should balance it better without so much weight hanging out to the sides of the chassis, nice design, where can I buy one?
Hopefully from me at some point soon.
ads0021 is offline
Old 02-09-2010, 01:08 PM
  #18
cwoods34's Avatar
I don't have an 009 in front of me, but I believe that the gearboxes are slightly different, at least the rear where the motor mount is. But, on your conversion you aren't using the stock motor mount, which is why I'm wondering how easy it would be to adapt to a 007.........
cwoods34 is offline
Old 02-09-2010, 01:28 PM
  #19
I use the standard front and rear gearboxes. And my own motor mounts. Is the motor mount, one piece with the rear gearbox?
ads0021 is offline
Old 02-09-2010, 01:36 PM
  #20
Originally Posted by gwhiz View Post
Nifty!
Does this company offer a 504mm (168T)?
Thanks.
Just checked. They do a 501mm and a 507mm but no 504mm.
ads0021 is offline
Old 02-09-2010, 01:39 PM
  #21
cwoods34's Avatar
On the 007, the motor mount also holds the layshaft, along with a piece opposite of it to hold the other side of the layshaft, but they are independent of the rear bulkheads/"gearbox". The rear bulkheads are fastened to the motor mount/layshaft mounts with a rear upper deck, so it is not a one-piece.
cwoods34 is offline
Old 02-09-2010, 01:54 PM
  #22
ddesros2's Avatar
Originally Posted by ads0021 View Post
Let me know you thoughts. The car have very quick and stable change of direction and seems to have no loss in speed due to the belt having an extra bearing to go round.
That is a neat design. Good job! If you do release it, let us know the conversion cost. That narrow platform would transition great in a tight technical track. Also, on a large flowing track, this could maintain better corner speed.
ddesros2 is offline
Old 02-09-2010, 01:55 PM
  #23
In that case it will either go straight on or need very minor changes to make it fit. I have just found out a friend of mine still has a 007. I will be able to have a good look tomorrow.
ads0021 is offline
Old 02-09-2010, 01:59 PM
  #24
cwoods34's Avatar
Awesome, I'll be awaiting more information.....
cwoods34 is offline
