comm lathe best for the money >
Old 03-28-2004, 08:13 PM
Default comm lathe best for the money
i am looking to get a comm lathe and would like to know which is the best for a resonable cost. i was looking at the trinity but your opinions will be helpful
big_bg is offline
Old 03-28-2004, 08:14 PM
the cobra is cheap and works great...get a diamond bit as well
R/C Anonymous is offline
Old 03-29-2004, 04:21 AM
Hudy Tech lathe is sturdy and true. It's a bit more but definitely worth it!
g_bruin is offline
Old 03-29-2004, 06:21 AM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Best for the money is the Integy Eagle MOD lathe. I got mine for about $90 bucks shipped from R&L Hobbies. It has the carbide V-Blocks which are the latest and greatest to have on your comm lathe and can use a bit for either side. Also the carbide bit that comes with it seems to cut for a long time.
Don't get a diamond bit, they can chip VERY easily and you will just cut comms out of round and not know what the problem is as it will still have that great finish. When a carbide bit gets dull, it will make the finish look dull. You can always just resharpen the bit or get a new one as they are really cheap. go to www.bigjimracing.com to in the tips section and read about carbide vs diamond.
Cain is offline
Old 03-29-2004, 11:05 AM
tc3rookie's Avatar
Slightly off topic... but whats the difference between mod and stick comm lathes? are the stock ones for NON rebutldable motors or what. thanx
tc3rookie is offline
Old 03-29-2004, 12:25 PM
AN
Hudy Advanced Comm Lathe - Modified - BBG vs Hudy Advanced Comm Lathe - Modified - HSG ??
/AN
AN is offline
Old 03-29-2004, 01:05 PM
tc3 u r correct on the subject
the owner at my local track got the Eagle lathe and said it was a p.o.s. he has me cutting his comm.s every once in awhile now
Old 03-29-2004, 01:32 PM
pro3racer's Avatar
really, wow, i was going to buy that lathe too, but the money kinda wasn't there at the time.
pro3racer is offline
Old 03-29-2004, 01:54 PM
hi Eric...it could be jason doesnt know how to set it up too...ya know the guy....he's not all there
Old 03-29-2004, 02:08 PM
RandyB's Avatar
FYI no such thing as a good cheap comm lathe it either does what its supposed to and is expensive of does a half as- job and is cheap.
sorry
RandyB is offline
Old 03-29-2004, 04:19 PM
The cobra lathe is it man! Comes with diamond bit and I believe either stormer or sheldon hobbies has them for $156.00.
Masterfaster is offline
Old 03-29-2004, 06:00 PM
rc_square24's Avatar
Default comm.s coning
how do you know if your lathe is coning your comm.?
im not sure if mine is because it usually takes a deeper cut around the brush contact area so i cant make out if its the wear or the lathe.
thanks
rc_square24 is offline
