-   -   Help needed please :( (https://www.rctech.net/forum/electric-road/367746-help-needed-please.html)
Chris Griffiths 02-05-2010 09:02 AM
Hi guys, im having a problem with the set up of my car, the electric side is 0.5mm higher than the lighter lipo side. ive checked tweak and its all fine, stripped car right down and rebuilt and chassis was perfect.
Im not sure if this is normal but its dosnt seem right to me?
Thank in advance for any help!
Chris Griffiths
Rozzer 02-05-2010 09:08 AM
Could be side to side weight balance.
Chris Griffiths 02-05-2010 09:13 AM
its perfectly balanced! im testing by putting screwdrivers under shock towers and lifting up car, if anything its lighter on the lower side?
niznai 02-05-2010 09:21 AM
Put the car on two pin stands and then you'll see if it's really balanced.
But this may not be the problem. Do you have equal tension on springs left to right? Equal shock rebound? All these affect the car's listing to one side.
Chris Griffiths 02-05-2010 09:37 AM
Yes everything is perfect, shock length, rebound, pre load???
Im lost with what it can be?? im thinking maybe a bent arm or somthing making the car lean on one side?
but it seems to change i centre of chassis
Randy Caster 02-05-2010 09:45 AM
Common problem would be uneven shock springs. Just adjust the preload to get the chassis level and then check the tweak.
Chris Griffiths 02-05-2010 09:50 AM
Ive checked tweak as it is now and its perfectbut ill get to work on that now
dietDrThunder 02-05-2010 10:49 AM
Don't get too hung up on the whole "everything is perfect" thing. Obviously everything isn't perfect, or the car would be straight.
re: shocks: if the ball ends aren't screwed on the same, that will change the length of the shock. Did you measure all 4 shocks off the car to see if they're the same? Also, you cna move the shocks around (swap them around) to see if you can make the other end higher.
Methodically measure everything, and you'll find the answer.
Chris Griffiths 02-05-2010 10:53 AM
Ok ive measured everything, i do this before building also but ive rechecked, all shocks are same length, roll bars are fine, rebond perfect.
Now as somone suggested ive just bought tamiya springs and one seems to be around .5mm out?? there quite hard to get a exact measurment on tho but ill try hpi springs again!
Thanks for all this advice guys
dietDrThunder 02-05-2010 11:01 AM
Ya, if everything checks out, then don't be afraid to take up the difference w. preload, like the other poster suggested.
Rozzer 02-05-2010 11:21 AM
If Droop and everything else is fine, It is probably bent wishbones or mounts for them, I cannot think of anything else
Chris Griffiths 02-05-2010 11:38 AM
Ok, im just putting HPI springs on as we speak so ill see if that changes anything.
One thing to note is when i put on blocks theres a gap on the lipo side but this is without lipo when lipo is on its fine so im persuming this is just a weight issue?
if this dont checkk out ill replace wishbones etc!
Thanks guys
PS i thought it was really bad to have opposite pre load on springs? is there a limit to how much difference?
stiltskin 02-05-2010 11:52 AM
I had a recent problem with a used car I bought. After investigation I found that the shock ball ends were different lengths. The shocks measured the same length, but the spring perches sat at different levels. Good thing to check.
Chris Griffiths 02-05-2010 12:00 PM
I may of sorted it, ive always took it you needed pre load to be exactly the same, if i screw down the lipo side 1/4 of a trun more its pretty close now?
Chris
