Old 12-16-2010, 02:37 PM   #121
Regional Moderator
CarbonJoe's Avatar
Originally Posted by mackin View Post
It won't break, just bend!
And if the left side bends, you get to cut it off.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-16-2010, 02:44 PM   #122
ghiro's Avatar
Send a message via Skype™ to ghiro
just like any other . . . BTW i've previously ordered one so i have the spare
Capricorn TE01-Associated RC10R5.1-Atomic VM2-Serpent Cobra811 BE-Honcho-Losi MRC/RcBros-SandScorcher-MERV
DJI' F550-HubsanX4-Toy'sPort Zorro
ghiro is offline   Reply With Quote
Old 12-16-2010, 03:17 PM   #123
tudor_47's Avatar
Originally Posted by ghiro View Post
My X10 finally came in on tuesday and the surprise is: the kit included an ALUMINUM rear axle .
No more axle issue . Thanks X-Ray
Now it's time to ask X-Ray the 235mm pod conversion
Yes, and how about getting them to making the motorpod larger so that we can use 48P gears.. such as 88/90T spur...
It will not fit today.
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 12-16-2010, 05:16 PM   #124
FOXY923's Avatar
I use 48p gears. 69 spur 29-31 pinion.
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 12-16-2010, 05:17 PM   #125
FOXY923's Avatar
Goods news about the axle.
RACE 4FUN
Old 12-17-2010, 07:52 AM   #126
ghiro's Avatar
What kind of servo you guys use on your cars?
I've planned to use an Orion low profile servo but the servo posts on the X10 are made for half sized and require to use an option part so i have used the orion L.P. in another car. I've then decided to get a proper sized servo but haven't an idea wich one ( i ain't gonna buy an Hitek) any idea?
Old 12-17-2010, 08:19 AM   #127
FOXY923's Avatar
I'd go with either JR or Futaba, I don't like HiTech servos.
If the mounting holes on the chassis don't line up with the servo just use shoe-goo. That's what I've done on 3 of my X10 chassis' and haven't had a problem yet. Just make sure you let it cure before using it.
RACE 4FUN
Old 12-17-2010, 10:01 AM   #128
ghiro's Avatar
How about this? will it fit or is it to small?
http://www.gpdealera.com/cgi-bin/wga...pgm?I=FUTM0303
Old 12-17-2010, 10:29 AM   #129
FOXY923's Avatar
I think that is too small. Any 12th scale servo will work. I don't know the number for it, sorry. As for the actual fit with the mounting holes, I have 3 servo's and none of them fit the mounting holes on the chassis, so I shoe-goo'd them in like I said earlier. Less weight that way to
RACE 4FUN
Old 12-18-2010, 03:15 PM   #130
ghiro's Avatar
Thanks Foxy,you were right, i went to a shop and saw the Futaba servo today,it's way to small for a 1:10 pan car,so i've used the longer servo posts i borrowed from my son's T3R and used the L.P. Orion servo.
About 235mm conv.n i think we better hit hard over here:
http://forum.teamxray.com/viewtopic.php?f=26&t=11004
Old 12-18-2010, 05:45 PM   #131
FOXY923's Avatar
Have fun, I have no intention to run 235mm. I'm waiting for some other stuff.
RACE 4FUN
Old 12-18-2010, 07:57 PM   #132
Regional Moderator
CarbonJoe's Avatar
Try the Futaba 9560 or Futaba BLS651.
Old 12-19-2010, 01:32 AM   #133
ghiro's Avatar
Futaba9560 is big as those i've ,to big.But the BLS is perfect ,there's only thing i'm concerned about is this servo: it's supposed to work only with NiCad's but not with Lipo's (2S) as stated in the factory spec's :
http://www.gpdealera.com/cgi-bin/wga...pgm?I=FUTM0567
I believe it can work well with 1S or 4NiCad's since it's made for 1:12th scale cars needs or 1S 1:10th scale cars but not with 2S. I wouldn't like to burn a 100+ bucks servo just to see if it works.
Old 12-19-2010, 01:49 AM   #134
Hello from France,
my servo is the savox 1251 (the same I use in my touring cars).
It fits without any problems. Just to add some shims under and above the posts.
Au revoir
romuald31 is offline   Reply With Quote
Old 12-19-2010, 06:44 AM   #135
Regional Moderator
CarbonJoe's Avatar
The 9650 and BLS651 are virtually identical in size. I use the both the 9650 and BLS651 in 1/12 scale with a 2s LiPo Rx pack with no issues.
http://www.gpdealera.com/cgi-bin/wga...pgm?I=FUTM0260
Besides, if you are using 2s LiPo for the main battery, your ESC has a BEC that reduces the voltage to 6.0v. The 2s LiPo Rx pack users are technically supposed to use a voltage regulator to drop the voltage to 6.0v, but I don't know of anyone that does.
Horsham Rc Carpet racing 2009 Jeff Cuffs Racing Forum 3890 09-12-2010 02:01 PM
Xray X10 World GT Car PitNamedGordie Electric On-Road 262 04-22-2010 03:18 AM
Three xray cars to be released at Nurnberg hobby show. ????? rx7ttlm Nitro On-Road 44 02-04-2010 02:06 PM
Custom Model Cars Zoidberg Australian Racing 224 09-04-2009 07:10 AM
